Old 07-31-2023, 03:17 PM   #1
imtb
Default Anti rattle brake rod clips
I just went through my brake rods and new pins. I am looking for picture of the anti-rattle clips installed.
The rear I have in front of the ball on the rod and the front I have the clip behind the ball. Does this sound correct?
Thanks for the help.
imtb is offline   Reply With Quote
Old 07-31-2023, 05:01 PM   #2
wrndln
Default Re: Anti rattle brake rod clips
You are correct. The rear anti-rattlers push the rod rearward to keep the shoes from dragging. The front anti-rattlers push the rods forward to do the same function.
Rusty Nelson
Old 08-01-2023, 01:08 AM   #3
TomInCologne
TomInCologne's Avatar
...away from the brakes towards the pedal...
TomInCologne is offline   Reply With Quote
Old 08-01-2023, 11:57 AM   #4
dmar836
Tom, For clarification, the springs/anti-rattlers themselves are mounted on the pedal side of the "ball" and push the rods toward the respective backing plates in order to prevent the springs pulling on the rods in the braking direction?
D
dmar836 is offline   Reply With Quote
Old 08-01-2023, 12:21 PM   #5
Jim Mason
Jim Mason's Avatar
Easy way to remember, Those are brake pull rods and spring returns.
www.jmodela.coffeecup.com
Fwiw, jm.
Jim Mason is offline   Reply With Quote
Old 08-01-2023, 01:31 PM   #6
TomInCologne
D
Hm, don't know how to understand that... I have mounted them so that they pull the rods into the direction of the pedal, or the middle of the car. The front ones pull to the rear, the rear ones pull to the front. am i having a brain-fart and being too confused?
Old 08-02-2023, 12:46 AM   #7
TomInCologne
good morning,
sorry, after a good nights sleep: yes, i must have been confused, very confused.
The brake rods are pulled by the pedal. The springs have to work in the other direction, pulling the rods in the direction to the brakes, so back in the back and to the front in the front.
Does that make sense? If not, please correct me!
