01-03-2011, 10:31 PM | #1 |
Acid Cleaning of Cast Iron
Don’t have ready access to media blasting so am considering degreasing with solvent and then soaking some small cast iron pieces (i.e. water inlet/outlet, etc) in acid prior to painting. Am I correct that muriatic acid is more aggressive than phosphoric?
01-03-2011, 10:49 PM | #2 |
Re: Acid Cleaning of Cast Iron
Muriatic is an unrefined version of HCL or Hydrochloric Acid. It is stronger than phosphoric. Check the label on Coke...contains phosphoric acid.
HCL will not attack copper and some other metals. Marc |
01-04-2011, 01:45 AM | #3 |
Charles in my opinion I wouldn't use the muriatic because it's difficult to flush away and nautralize... an even bigger problem given the porous nature of old cast iron. You'd likely end up with the pieces turning very rusty over the ensuing weeks, right through the paint... as that nasty muriatic leachs out!
Phosphoric will clean the cast well and is more forgiving, although getting a good "etched" surface that will promote adhesion to primer & paint takes some experimenting. Basically I would use phosphoric and a stiff brush to clean...flush with a thinner diluted mixture & blowgun dry. Next, get them in front of a heater & watch the cast dry up as it warms. Do a final scower with a fine bristle brush(wire) to remove any residual acid powder...a scotbrite pad works OK too...then dust on a very thin coat of etching primer, let primer dry & then paint while still warm so as it flows out nice and thin ...2 coats would be good ...then let it bake for a while and set up. I sometimes lay a cardboard box on it's side and point a ceramic cube heater inside, then line up all your little pieces on "the stage" and let er cook with the box as a backstop. |
01-04-2011, 02:13 AM | #4 |
How about http://www.evaporust.com
01-04-2011, 02:17 AM | #5 |
Charles, watch out with the phosphoric, I used to use a phosphoric tank very successfully to remove rust etc. I did however have a couple of disasters, one was with a carb. and the other with an inlet manifold. I think I left them in the solution a little too long. Both became so soft you could scrape the metal with your fingernail and leave a mark. Someone told me afterwards phosphoric removes the carbon from cast iron.
01-04-2011, 05:02 AM | #6 |
Cast iron does not get black rust like steel does. Wire brush will see you out and your grandkids. Acid will leach into the cast pores. |
01-04-2011, 06:59 AM | #7 |
Muriatic acid leaves behind chlorine atoms that will recombine into hcl. This will cause rust to form later even under paint.
You are much better off looking up electrolytic rust removal and try to get some carbon electrodes. Other choices include molasasis and evaporust type products. These methods are safe and hard to mess up. Electolytic rust removal will also fully remove the cl ions left behind from muriatic acid. |
01-04-2011, 10:30 AM | #8 |
Ditto Bick's experience with softening the cast iron if left in HCl too long. A short time might be O.K. Neutralize the acid remaining in the part. Give it plenty of time. There should be no odor if fully neutralized.
01-04-2011, 11:05 AM | #9 |
soak greasy parts in simple green pro HD from homedepot. http://www.simplegreen.com/products_pro_hd.php. Them wash in bucket filled with hot soapy water (dish detergent). If you have rust soak in evaporust (available at harbor freight). Wire brush clean and paint. You can buy a wire brush for a drill at homedepot.
01-04-2011, 11:44 AM | #10 |
Don't use muriatic acid on cast iron. I did, but only once! After a couple of days I took the cast iron out of the solution and it literally crumbled in my hand. I also tried muriatic acid on a 1" hot rolled square shaft and when I took it out of the solution there were channels eaten away in the shaft. It looked like termites were at work. Now I only use phosphoric acid or the electrolytic method, but mostly the electrolytic method with a final wash in phosphoric just to take care of any surface rust.
01-04-2011, 01:43 PM | #11 |
Phosphoric acid is safer and also leaves a deposit of phosporus on the metal which is similar to Ford's original bondorizing process.
I buy mine in the Home Depot paint department. It is labeled "metal prep". It leaves a deposit you may think is rust but it isn't. Leave the coating on and paint right over it. Don't let it sit around. I'm sure it would rust eventually. Never had a problem with it "yet". Richard Anaheim CA |
