05-23-2017, 01:43 PM | #1 |
gasket question
is there supposed to be a gasket between the front of the bell housing and the back of the engine? or maybe just permatex?
05-23-2017, 01:49 PM | #2 |
Re: gasket question
This goes between the flywheel housing and the engine.
Bob |
05-23-2017, 02:20 PM | #3 |
Re: gasket question
Don't forget the U-shaped flywheel housing shims, between flywheel housing and block, to balance this gasket thickness out. See "How to Restore Your Model A," Vol. 4, pg. 10.
Jim Cannon Former MAFCA Technical Director "Have a Model A day!" |
05-23-2017, 05:04 PM | #4 |
Re: gasket question
Be sure to install the gasket with the round area over the camshaft. It doesn't work very well when installed the opposite way. It will leak like a sieve. I believe that is why many use the permatex instead of the gasket.
05-23-2017, 05:17 PM | #5 |
Re: gasket question
I used both a gasket and some permatex....
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
