04-30-2016, 02:25 PM | #1 |
Front Cross Member Problems
I'm restoring a 29 town sedan that came from N. Dakota and the front cross member had a really bad farm repair so I replaced it with what I thought was the right cross member, when I put the radiator in it doesn't fit, it was hitting the bracket with the crank hole, so I took the crank hole bracket off thinking I had the wrong one and it's still bottoming out on the drivers side even without the crank hole bracket. I must have the wrong year cross member hopefully someone can tell me what to look for and maybe have one I could buy. I was hoping to get this going this year, this is a real set back, it was a lot of work for me riveting that cross member in there; I was getting ready to start the motor. Any help would be appreciated. Thanks, Bob
04-30-2016, 04:16 PM | #2 |
Re: Front Cross Member Problems
That's a late 29-31 cross member, you just need to put a shim were the
radiator sits. Page 387 of the Service Bulletins shows this conversion. Bob |
04-30-2016, 04:48 PM | #3 |
I am not this good at judging this but does he have a 1930/31 cross member rather than a 1928/29??
Fred Kroon 1929 Std Coupe 1929 Huckster |
04-30-2016, 05:46 PM | #4 |
Yes, the easy way to tell is where the crossmember leaves the frame rail, it would be level for the 28-9 , but notice how this 30-1 has a dip of about 1/4". The fix is easy, as Bob said, just need to add a shim about 1/4" to each side for the radiator to set on.
04-30-2016, 07:09 PM | #5 |
I have the same problem....30-31 crossmember on a 29 pickup.
I used two 1/8" pads between the radiator mount and the crossmember on each side...works fine.. This is what the vendors sell. http://parts.modelastore.com/show_Product.asp?ID=3754 I think old tire sidewalls would work too...
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
05-01-2016, 10:11 AM | #6 | |
01-23-2017, 01:53 AM | #7 |
Why did you put washers above the castle nut?
01-23-2017, 01:57 AM | #8 |
Would be nice if people who ask for help would update the status.
Thread Tools | |
Display Modes | |
