Old 10-26-2021, 08:05 AM   #1
48fordnut
48fordnut's Avatar
Default Spindle /king pin spacer.
Rebuilding a stock model A ft spindles and bushings.
There is a 3/16 to 1/4 space between the assembled spindle and the axle. It is at the bottom of the spindle. There should be a shim/washer there. I do not have one in my kit. The old parts did not have one either.
What to do?
I'm new to model a so go easy.
Thanks,
jim
48fordnut is offline   Reply With Quote
Old 10-26-2021, 08:34 AM   #2
MAG
MAG's Avatar
Default Re: Spindle /king pin spacer.
Jim, there should be a felt seal there to prevent dirt from entering the area, See Bratton's PN 4390.
I noticed the harder I work the luckier I get!
MAG is offline   Reply With Quote
Old 10-26-2021, 10:22 AM   #3
48fordnut
48fordnut's Avatar
Thanks.
I did a google search for an expanded model a ft end. It shows a metal spacer onder the spindle and on top of the axle.
Old 10-26-2021, 10:30 AM   #4
Will N
Will N's Avatar
There needs to be a little space there even after the felt and cup are inserted. All the weight should be born by bearing at the top of the spindle, and the steering knuckle needs the clearance at the bottom where you see the space so that it can rotate freely without binding.
Will N is offline   Reply With Quote
Old 10-26-2021, 11:42 AM   #5
Bob C
Snyder's has the parts. https://www.snydersantiqueauto.com/p...7702&cat=41626
https://www.snydersantiqueauto.com/p...7706&cat=41626
Old 07-16-2022, 04:44 PM   #6
saxman657
I have a question pertaining to this, but can't find a clear answer anywhere. Should the felt washer cup be facing with the felt against the axle, or facing down, with the felt against the king pin bushing. Its clear that the shims go under the thrust bearing, but not sure about this felt washer/cup.
saxman657 is offline   Reply With Quote
Old 07-16-2022, 08:13 PM   #7
Synchro909
Synchro909's Avatar
I just checked Les Andres' book so I could answer this one for you but he doesn't show it (Pages 1-6 and 1-9). He shows the felt washer and cup on the under side of the axle and I always assemble the felt under the steel cupped washer. I figure its job is to stop road grime from getting into the lower bushing and ruining it.
Old 07-16-2022, 08:49 PM   #8
saxman657
Answer: felt washer on the bottom, cup washer on top of the felt.
Old 07-17-2022, 03:51 AM   #9
Bruce of MN
Bruce of MN's Avatar
See https://www.brattons.com/FRONT-BRAKE...tinfo/AD%2D01/
Old 07-17-2022, 09:50 AM   #10
saxman657
Yup! This diagram came from MAFCA and answered my question. It’s the only schematic I have found with this kind of detail.
