Old 09-09-2020, 04:19 PM   #1
ronn
Default I went picking today.........
28-29 radiator for 50. (stant cap included)
28-29 visor for trk 20.
pair of 30-31 headlights along with an extra set of ford lights yr undetermined 80.(think 32 ford trk)
2 A or T jacks at 10. each
pair of used 30-31 running boards for 30.
30-31 deluxe windshield frame 15. (this is the piece that made me take the ride)
12 volt ahoogha horn 10. (newer chromed model)
found on CL up in NY-I was bored, so I took the ride.
anybody else having fun yet?????????
Old 09-09-2020, 06:29 PM   #2
Jack Shaft
Default Re: I went picking today.........
I went picking last week
Found outside Petaluma,FB marketplace '39' style late synchros and dual detent top loader V8 transmissions and oodles of parts
Old 09-09-2020, 07:10 PM   #3
McMimmcs
McMimmcs's Avatar
When you go picking, you truly go picking ! Big garage I hope.
Old 09-09-2020, 10:33 PM   #4
dbaldwi3
dbaldwi3's Avatar
Nice find!
dbaldwi3 is offline   Reply With Quote
Old 09-09-2020, 10:59 PM   #5
Jack Shaft
Storing is no problem,bead blasting and identifying everything,thats the problem..a bunch of revisions and countless gear combinations from 32 to 51..model a is easy...
Old 09-10-2020, 05:54 AM   #6
ronn
sweet! fun to get out...........
Old 09-10-2020, 06:17 AM   #7
David R.
I seem to be in a model A desert. Not much around here. Went to a pretty good swap meet last fall a couple hours away, one locally held had zero model A stuff. Most things cancelled for the covid.
David R. is offline   Reply With Quote
Old 09-10-2020, 07:08 AM   #8
ronn
the guy I went to still has some motors- a and v8-trans heads springs etc. if anyone needs anything......... near Ithaca
Old 09-10-2020, 07:21 AM   #9
Jack Shaft
There are a bunch of outlets where folks post stuff up,Offer up,Marketplace,Partswapper..Cars for sale ads is where I found some real gold,a fella selling his car sometimes has a stash of parts that 'go with it' I call to buy the parts only and have done well,the seller was going to give them with the car,he's glad to get something for them..
Old 09-12-2020, 12:01 AM   #10
48fordnut
48fordnut's Avatar
There is a guy on the Hamb looking for a rolling chassis in Tx and can't seem to find one.
48fordnut is offline   Reply With Quote
Old 09-12-2020, 07:59 AM   #11
Joe K
Joe K's Avatar
Most librarians I know don't read a lot. For them the Dewey Decimal System is where it's at I guess.
Truly, I have the same problem. 100 percent of the first Model A, 60 percent of the second, 40 percent of the third - and a whole bunch of other parts I'm gonna get to someday.
And a wife who says "When you die, it's all going to scrap!"
Its called "Transgenerational Passage of Wealth." But what if the next generation doesn't know value?
Joe K
Shudda kept the horse.
Old 09-12-2020, 10:17 AM   #12
Jack Shaft
Ford made quick reference gear charts based on the year of the car,it would make life easy..if i knew what car they came out of but when they come in boxes and bucket you have to identify each part them go back to the actual gear charts to see what works together. "Nancy Drew in the Case of the Missing Gear"
Been working with the 3 year old grandson about the car,the older ones would fight over who is taking the crap to the scrap yard.
Oh,and some engineer at Ford should be shot for deciding on the snap ring style,instead of the standard 'points on the outside of the gap' they appear to be cut...point on outside on one side of the ring,inside on the other..cant use ring pliers,you have to use a pick..about fifteen minutes in you want a piece of that engineer..
Old 09-12-2020, 12:42 PM   #13
McMimmcs
McMimmcs's Avatar
A true picture of a hoarder!
Old 09-12-2020, 01:17 PM   #14
Jack Shaft
Yeah...so? ... actually my plan is to put a few decent transmissions back into circulation, keep one or two for myself.They spent the last fifty years or so in a barn,set up with a clings kit and closed driveshaft they drop right into a model A..modern synchronized shifting but still the old ford smell..and a swan neck shift lever..
Old 09-12-2020, 01:21 PM   #15
deuce5wndw
deuce5wndw's Avatar
Is that one of the Canadian aluminum heads in first photo? What do you think the transmissions with the chain sprockets were used for?
deuce5wndw is offline   Reply With Quote
Old 09-12-2020, 01:29 PM   #16
Jack Shaft
Nope,thats a core 59AB head I used for a template to make a block off plate to pressure test with.
The cat that had the transmissions ran a drilling service,old International crawler tractors with a pipe rack and a king swivel,they would use the transmission to run a hydraulic pump.When they found out the trannys worked they went to Petaluma and bought a bunch of parts and trannys from the local transmission shop..they closed the drilling business years ago,finally sold the stash..
Old 09-12-2020, 01:35 PM   #17
deuce5wndw
deuce5wndw's Avatar
Thanks, the white on it made it look aluminum. Interesting story.
Old 09-12-2020, 05:21 PM   #18
ronn
or a smart guy who knows how to make a buck from pennies...........
Old 09-12-2020, 05:41 PM   #19
Jack Shaft
Just an old mechanic who enjoys working on old fords..to me hoarding means buying and holding..although I can finance my car out of pocket its sweeter If I can do something like this,build one for me,sell some parts or complete transmissions.keeps me off the streets..
Old 09-12-2020, 07:58 PM   #20
McMimmcs
McMimmcs's Avatar
You took exception to it when no ill will was intended.
