Go Back   The Ford Barn > The Archives > Late V8
Old 01-01-1970, 12:00 AM   #1
Guest
Posts: n/a
Default 1969 Fairlane 500 Ftbk
Ok,
My 69 fairlane 500 has a 351,4v, fmx auto, and 3:73 3rd member. My question is this
the door stamp says "6_x" I dont know which 351 block I have?
<table><tr><td><font face="arial">
<ul>[*]The most powerful hand held lasers on the planet!![/list]
Old 01-01-1970, 12:00 AM   #2
Guest
Posts: n/a
Default Re: 1969 Fairlane 500 Ftbk
If the timing gears fit under a cast cover that bolts to the block under the water pump,its a windsor.The cleveland had a stamped metal cover that fit over the timing gears.Also the distributor is in the intake manifold on a windsor and in the block on a cleveland.
i hope i didn't mess up and lie to you
