Old 05-06-2020, 07:29 AM   #1
RTPbee81
RTPbee81's Avatar
Default Tire Tube replacement question?
Tires were replaced (they are Universal) prior to my purchase due to dry rot, they appear new, the spare had never hit the pavement (nubs were still intact), until Sunday. Tube valve separated from the stem so assuming the tubes weren't replaced, all valve stems look pretty old.
I ordered new tubes and liners from Coker, should be here tomorrow, I have a friend who owns a tire shop but has never mounted a tire for an A, any suggestions or things to look out for when he dismounts the tire's and replaces the tubes?
He mentioned he has no idea what he will find once he takes out the tube...
RTPbee81 is offline   Reply With Quote
Old 05-06-2020, 07:57 AM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Tire Tube replacement question?
There are several topics related to this here, -and Ray White has one on YouTube. YOu may want to search this a bit and print off for your tire store friend.
One of the reasons why stems separate from the tube is because the tube/tire is slipping on the wheel. The Model-A wheel was never designed to have a rubber stem tube. For years this was 'allowed' simply because the rubber stems in tubes were very heavy duty in construction, and they were vulcanized well. Today this is a problem. I will also tell you that we rarely find people complaining about tube issues when the proper metal valve stems are used. Just some food for thought.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 05-06-2020, 04:23 PM   #3
Patrick L.
Patrick L.'s Avatar
Usually one can just remove one side wall and remove the old tube, look around to see the condition of the rim. If the rim is good just put in a liner and the new tube. If the rim is nasty then the tire needs to come off and the rim cleaned.
Old 05-06-2020, 04:49 PM   #4
Charlie Stephens
Be sure to CAUTION YOUR FRIEND that the Model rims are not nearly as strong as modern steel rims and an air powered changer can easily damage the rim by bending it. He either needs to be very careful or break them down using tire irons. A lot of truck shops have tire irons if he doesn't.
Charlie Stephens
Old 05-06-2020, 05:11 PM   #5
McMimmcs
McMimmcs's Avatar
Numerous posts on this subject and youtubes! Follow Brents advice in post #2. No need to go any further!
Old 05-06-2020, 05:57 PM   #6
Synchro909
Synchro909's Avatar
Really??? He owns a tyre shop and has no idea what is inside the tyre??? You have to be kidding!
Old 05-06-2020, 07:08 PM   #7
Sunnybrook Farm
Sunnybrook Farm's Avatar
I left my wheels on the car and used model A tire irons to get the tires off and one. Being on the car seemed to be easier than taking them off, once I got them loose I could just pull it off the rim. I guess back in the day people changed a lot like that, just felt like it was made to work that way. Of course I am too cheap to take them anywhere.
Sunnybrook Farm is offline   Reply With Quote
Old 05-06-2020, 08:20 PM   #8
Charlie Stephens
In addition to knowing what to do be sure he doesn't hand it off to the high school student they hired last week. Those wire wheels bend easily. I do mine myself with the tools in the attached photo (just 2, not all 4). I think the ones in the Ford tool kit are a little small but they work. Maybe someone in a local club could loan you the tools and show you how to use them. Just be sure you don't pinch the tube when you put them back together.
Charlie Stephens
Old 05-06-2020, 08:26 PM   #9
History
History's Avatar
My father in law has owned a tire shop for over twenty years and stays very, very busy. I don't think he has ever changed a model A tire.
I changed all my tubes myself using hand tools, it's pretty easy. I'd do it myself if I were you depending on your health and ability.
History is offline   Reply With Quote
Old 05-07-2020, 05:32 AM   #10
Bruce of MN
Bruce of MN's Avatar
I made this bead breaker to take off some 30 year old Allstate tires:
(The spare tire cover was left on for this posed shot, I didn't work on that wheel with it on!)
Old 05-07-2020, 01:49 PM   #11
Ak Sourdough
Ak Sourdough's Avatar
I have a couple of these bead drivers in my tool inventory. Just used one a few days ago changing to 21" radials. Works fine for the little soft tires on a Model A. Not enough usually for a more modern trailer tire or the like that has bonded itself to the wheel over time.
Just put it between the tire and the wheel and give it a couple wallops with a 3 pound hammer.
It's about a foot long and weighs a couple pounds. Made by Ken-Tools.
Ak Sourdough is offline   Reply With Quote
