07-13-2014, 01:27 PM | #1 |
What coil /resistor to use on 12 volt conversion on an 8BA.
When converting from 6 to 12 volts, which 12 volt coil do you use? Which resistor? Can u use a 12 volt coil that has a built in resistor? Does anyone have part numbers?
07-13-2014, 01:53 PM | #2 |
Re: What coil /resistor to use on 12 volt conversion on an 8BA.
I found that a 68 chevy pu coil and resister works well and the coil fits the holder.
07-13-2014, 04:39 PM | #3 |
pickup,
Bosch makes a 12volt coil...their # 00012....it is also available thru some CARQUEST stores using CQ #wpcf3000424875b05 BUBBA put me on to this coil...no resistor needed...it has 3.3 ohms built in. It is blue in color and commonly known as the 'super coil'. Watch the polarity neg ground...... minus side of coil to the dist pos ground......plus side of coil to the dist Charlie ny Last edited by Charlie ny; 07-13-2014 at 05:01 PM. Reason: ditto marks not lined up |
07-13-2014, 04:49 PM | #4 | |
07-13-2014, 04:54 PM | #5 |
Scroll to the bottom of this thread.
http://www.fordbarn.com/forum/showthread.php?t=131960 |
07-13-2014, 05:12 PM | #6 |
Opps! I forgot it was a conversion. Posting deleted. I used this coil and resistor for my 12V conversion using a distributor with points on an 8BA http://www.summitracing.com/search?S...ory%20resistor http://www.summitracing.com/parts/maa-29217 Last edited by 19Fordy; 07-13-2014 at 05:29 PM. |
