04-08-2013, 09:09 PM | #1 |
Front Brake Lever Pins
what is the 'OD' of A2085 Front Brake Lever Pins? Thanks!
04-09-2013, 12:01 AM | #2 |
Re: Front Brake Lever Pins
1/4" if I am reading Les Andrews Vol I page 1-32 correctly. Brattons says the same 2013 catalog page 12.
04-09-2013, 12:12 AM | #3 |
Thanks ... i was using Snyder's for # reference since Brattons does not use Ford #s.
04-09-2013, 09:38 AM | #4 |
Well....I couldn't find "A-2085" in the PPL's that I have.
Is this the clevis pin for the brake rods? If "yes", then it is .3125" or 5/16". Dudley * OK...just had some Coffee.....I'm not sure what size the pin is that holds the arm too the shaft...* Last edited by d.j. moordigian; 04-09-2013 at 09:57 AM. |
04-09-2013, 03:40 PM | #5 |
A-2084 Front Brake Lever........ Front Brake Lever Pin.........Order A-23766....... A-23766.......1/4 x 15/16 flat head pin............... |
