05-21-2018, 08:05 PM | #1 |
First Time start
Getting ready for first start of overhauled, re-installed'49 flathead engine. Have checked electric fuel pump, carb, and lines for fuel leaks and all is clean.
This is a 1.5 ton Ford F5 truck (big, heavy) in my garage. Moving it out of the garage would be major production. Moving it back in if it doesn't start would be nigh impossible (driveway slopes up to garage). I am thinking of starting it in the garage with 6 people with fire extinquishers standing by to pop either the extinquishers or the champagne bottles depending on outcome. What are your expert opinions on doing this? Is this a crazy hazard, fire or otherwise, or am I being overly cautious? Any tips on how to do this? thx Alan |
05-21-2018, 09:41 PM | #2 |
Re: First Time start
With an electric fuel pump, you can find a sunk float or any leaks before you try to fire it up. But it is a good idea to have a fire extinguishers handy. Fire away. Once you have it running, have a bottle of MMO handy to drizzle into the carb a few times during the first 20 minutes or so. Fresh valves and guides can be a little sticky for a while. It took my rebuild a few hours on the road for the compression to even out between cylinders.
05-21-2018, 10:51 PM | #3 | |
enough to take it outside. You can't drizzle MMO when it's in the garage, the smoke will kill you. Or you could get out of the building and the building will get exterminated. G.M
www.fordcollector.com |
05-21-2018, 10:55 PM | #4 |
05-21-2018, 11:06 PM | #5 |
You really need to run it and have load on it, sitting on the spot wont do it any good.
"Came too close to dying to stop living now!" |
05-21-2018, 11:15 PM | #6 |
