07-09-2021, 03:47 PM | #1 |
Just curious x 2
1) I read that the muffler design is what gives the Model A its unique sound. If one were to install a Toyota 22R or Pinto, Jeep or other 4 cyl engine with the Model A muffler, would it sound the same ?
2) there are several high compression heads available. Why can't an original head just be planed? Don't mean to be a pest, but there is so much to learn about these cars, and if I don't ask I won't learn. |
07-09-2021, 03:52 PM | #2 | |
Re: Just curious x 2
Also, I don't know the deck thickness of a stock head. Taking too much off may make it too tin. |
07-09-2021, 04:12 PM | #3 |
Russell, you’re not being a pest. This site was built to help people with questions and problems with their Model A. Come on in and make yourself comfortable. We have all been where you are right now.
07-09-2021, 04:19 PM | #4 |
Someone stopped by my house one night with what appeared to be a nicely restored Model A. He left it idling and it sounded stock. He lifted the hood and it had a 4 cylinder Chevy II engine with a stock Model A muffler attached. So the sound is in the muffler (and probably the 4 cylinder engine).
As far as planing the stock head there is not enough metal to plane enough to make a difference, you really need to get a high compression head. Charlie Stephens |
07-09-2021, 06:03 PM | #5 |
We had an A at a meet some years ago that sounded totally stock as it went through the gymkhana , turned out to have a Pinto engine going through a stock A muffler. It just idled a bit smoother.
07-10-2021, 09:54 AM | #6 |
If you research these online, you can find pictures the different shapes that are used; Winfield, Lion Speed Head, Rocket 428, Brumfield, even Snyder's and a few others. There are a lot of interesting ideas that have been tried over the years. |
07-10-2021, 10:18 AM | #7 |
MMM Interesting thread. At 71 years young I have been around car stuff my entire life. Having a head milled was a real big thing back in the day. That being said, once the head was milled was additional work done to the combustion chambers??
07-10-2021, 10:31 AM | #8 |
I have never heard of someone tampering with the chamber shape on an original head of a Model A, maybe other cars. Like said before, there is not enough material to mill off to make a difference. People looking for speed saw this and found a high compression head. Aftermarket high compression heads have been available pretty much since the 1930s. Different ratios, different chamber shapes, styles. The big ones are still made today.
"The more things change, the more they stay the same." |
07-10-2021, 01:42 PM | #9 | |
Not comparable to a high compression head but is does make a difference. Bill |
07-10-2021, 03:24 PM | #10 |
Bill you are right, that is what I meant to say lol!! A difference yes, but not a big one.
07-10-2021, 10:52 PM | #11 | |
07-10-2021, 11:32 PM | #12 |
I once fit a glasspack muffler on my car and it sounded like a modern 4 cal car! Changed it back quickly.
