Old 05-22-2020, 04:32 PM   #1
Licensed to kill
Licensed to kill's Avatar
Default Installing temp gauge.
Putting a temp gauge in my car. What route have others taken with the probe wire from the gauge to the water neck?.
Licensed to kill is offline   Reply With Quote
Old 05-22-2020, 04:39 PM   #2
Ruth
Default Re: Installing temp gauge.
Ruth
Old 05-22-2020, 06:35 PM   #3
shew01
shew01's Avatar
This works for me.
shew01 is offline   Reply With Quote
Old 05-22-2020, 07:38 PM   #4
Y-Blockhead
Y-Blockhead's Avatar
Mine follows the junction box to alternator wire then routed up the steering column.
Old 05-24-2020, 07:54 AM   #5
Licensed to kill
Thanks for the pics.
Old 05-24-2020, 06:00 PM   #6
monto
monto's Avatar
Another choice :-
Cut top radiator hose to accommodate a double nipple with adaptor into which temp sensor can be installed.(Tam's, Mac's, Bratton's) Run conductor along radiator stabilizer rod secured with wire ties and then through firewall.
'30 Coupe
monto is offline   Reply With Quote
Old 05-25-2020, 07:33 AM   #7
30 Closed Cab PU
Originally Posted by monto View Post
Another choice :-
Downside of using an in coolant hose water temp probe adapter is if you run a thermostat. Can not place the thermostat properly as close to the block as possible.
30 Closed Cab PU is offline   Reply With Quote
Old 05-25-2020, 08:44 AM   #8
1931 flamingo
1931 flamingo's Avatar
Are a few inches really going to matter??
Paul in CT
Old 05-25-2020, 09:11 AM   #9
30 Closed Cab PU
Paul in CT
The issue is when using a gauge and having a thermostat.
I found when my thermostat migrated from the block/pump neck to the radiator the motor ran 10 degrees hotter, and saw 5-10 degrees fluctuation in the gauge reading, readings were not stable. This is the probe in the neck.
The recommendation is to have the thermostat after the probe to reduce gauge fluctuations of the thermostat opening closing. And also best place to read the motor coolant temp is as close to the block as possible.
So in my case the thermostat would be away from the block and closer to the radiator, motor would most like run hotter, and see more fluctuations in the gauge reading.
At one point I took the thermostat out and used an IR Temp Gun. I was surprised there was a difference on the hose at 1/2 inch away from the radiator neck, to the hose 1/2 inch away from the block/pump neck. I do not remember now how much, but it was more than just a couple of degrees.
I guess it depends on how well your cooling system is, and if you can live with an extra 5- 10 running hotter, and if you can live with the gauge fluctuations.
Old 05-25-2020, 10:14 AM   #10
shew01
shew01's Avatar
My previous thermostat and temperature gauge were installed in the middle of the top hose, using a metal “T.” I had a lot of fluctuations in the gauge readings. It was a 180 degree thermostat with two small relief holes drilled into it, but the temperature gauge would swing back and forth, like a slow clock pendulum, between 170 and 190 degrees all the time while driving the car.
I have since replaced the upper water outlet with a product from Vintage Precision, which places the thermostat and temperature gauge hookup adjacent to the block. I’ve been working on other items while I had the car apart; so, I haven’t refilled the radiator yet to determine if the fluctuations are still there.
Old 05-25-2020, 10:32 AM   #11
Y-Blockhead
I guess that pretty much proves 30 Closed Cab PU's point...
Old 05-25-2020, 10:58 AM   #12
chap52
chap52's Avatar
I did like Yblockhead showed in his photo. Worked great... Chap
chap52 is offline   Reply With Quote
Old 05-25-2020, 02:15 PM   #13
30 Closed Cab PU
Mine is also like Y Blockhead's, but is not pretty like his.
Old 05-25-2020, 02:41 PM   #14
DNLs1930
DNLs1930's Avatar
Mine runs from the sensor straight up to the radiator support rod, over to the firewall then down to a wire harness and goes through the firewall at the steering column opening. It then runs up the steering column where a C clamp holds the gauge mount.
DNLs1930 is offline   Reply With Quote
