Old 03-03-2020, 08:45 PM   #1
Dennisfly
Dennisfly's Avatar
Default Duplicate Key
I have what I believe is a reproduction pop out ignition switch with only one key. I would like a duplicate key. The key says "Made in Spain" on one side and has a diamond with a 'W" in it and the numeral 1 on the other side. Any ideas where to find one? The local hardware store was no help.
1929 Town Sedan (Briggs) 155B, Mitchell Overdrive
1935 Model 48 Tudor
Dennisfly is offline   Reply With Quote
Old 03-03-2020, 09:14 PM   #2
Bob C
Default Re: Duplicate Key
Found this on another site.
I would like to add my information about MADE IN SPAIN popout switchs for the 28- 31 Ford...I have 2 ..1 seems to be older and has a removeable back plate with a diamond with a W in it and a number 1 printed on it ...I found that the key blank from a1951 thru 64 ford will fit it. ILCO HFD6 or OFD6....The second one looks like new has a removeable back plate with nothing printed on it but has a 0 on the part that the key goes into....I found that a key blank for the original Ford popout ford switch will fit this and is sold by Snyders and Bratton Ford parts......I bought these popout switches used with one key each but want more keys for each.....It seems like the key codes are 0-9 on the ones MADE IN SPAIN.....They both work fine.....Hope this info will help someone....George
Old 03-03-2020, 09:15 PM   #3
M2M
M2M's Avatar
With that Spanish made pop-out you might want consider replacing the switch rather than finding extra keys. Sorry.
M2M is offline   Reply With Quote
Old 03-03-2020, 10:17 PM   #4
Dennisfly
Dennisfly's Avatar
Thanks Bob. Exactly the info I needed.
1935 Model 48 Tudor
Old 03-03-2020, 10:19 PM   #5
Dennisfly
Dennisfly's Avatar
M2M
Sounds like it would be a good idea to carry a spare switch!
1935 Model 48 Tudor
Old 03-05-2020, 01:30 PM   #6
monto
monto's Avatar
Even if it's not a pop-out switch, suggest you get one for which you can obtain duplicate keys (USA) and avoid the frustration.
'30 Coupe
monto is offline   Reply With Quote
Old 03-05-2020, 04:06 PM   #7
Don/WI
Why would anyone want to replace the switch if they have a keyand the switch is working ? With the Information contained in #2 above a duplicate key can be made. Problem solved. Don/WI
Don/WI is offline   Reply With Quote
Old 03-05-2020, 08:36 PM   #8
M2M
M2M's Avatar
Do a search on Spanish pop-out switches and you'll see why.
