Old 01-10-2020, 05:59 PM   #1
oldford2
oldford2's Avatar
Default 53 pickup kup3speed floor shift into a 46 pickup
What, if any, mods are required to put a 53 pickup 3 speed floor shift into a 46 3 speed floor shift pickup?
Thanks
John
oldford2 is offline   Reply With Quote
Old 01-10-2020, 07:50 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: 53 pickup kup3speed floor shift into a 46 pickup
Thanks
John
Maybe you should click on this link BELOW and start reading at Post #12. '53 truck sounds like a real oddball, and this swap (as you contemplate) could turn into a real disaster. To start with, you're talking about two totally different transmissions, not to mention the bellhousing differences. DD
https://www.fordbarn.com/forum/showt...p+transmission
Click Links Below __
T5 W/TORQUE TUBE
Old 01-10-2020, 08:22 PM   #3
oldford2
oldford2's Avatar
Thanks for the info Coop. I just read that post.Sounds like I would be headed for a can of worms. Looks like the best approach is to pull the 46 transmission and rebuild it. It now pops out of second and has a bad sound in first (broken tooth?). MacVp's book will now be getting more greasy pages.
Thanks again
John
