Old 11-14-2020, 12:36 PM   #1
hmmech
Default 302 eng.W/ c-4 trans to a 53 car
what needs to be done for this swap, help needed before i start, like to keep my automatic column shift .
hmmech is offline   Reply With Quote
Old 11-14-2020, 06:32 PM   #2
chain drive
Default Re: 302 eng.W/ c-4 trans to a 53 car
any one ever run a wilson cam in a y-block?
chain drive is offline   Reply With Quote
Old 11-14-2020, 08:07 PM   #3
KULTULZ
KULTULZ's Avatar
Post Re: 302 eng.W/ c-4 trans to a 53 car
Start Here -
https://www.fordbarn.com/forum/showthread.php?t=289300
KULTULZ is offline   Reply With Quote
Old 11-20-2020, 01:16 PM   #4
JeffB2
JeffB2's Avatar
I can walk you through the whole swap using this makes it easy. https://butchscoolstuff.com/52-53-fo...t-kit-2501cpb/ Here are pictures of an install the Ford AOD with it's .67 overdrive is a better choice over the C4 and Lokar makes the linkage to mate up with you Ford-O-Matic column. As you can see here the AOD will sit right on your existing stock transmission cross member by re-drilling the mounting holes the C4 requires fabricating an extension plate also the AOD works better with your stock rear end ratio you will cruise at about 2000 RPM at 70 MPH in overdrive but around 3100 RPM with a C4. The best Donor would be the 302/5.0 from 1984-93 as they also have the correct oil pan for the swap and dipstick location.
JeffB2 is offline   Reply With Quote
Old 11-20-2020, 01:20 PM   #5
JeffB2
JeffB2's Avatar
This shows the Lokar ACA-1807 linkage to your Ford-O-Matic column
Old 11-20-2020, 07:22 PM   #6
51504bat
51504bat's Avatar
Jeff,
I'm in the process of installing a 302/AOD combo in my '54 Ranch Wagon. I have a '54 automatic column. Will the Lokar ACA-1807 linkage work? Per the sites I looked at it is designed for an AOD using a Chevy column. Thanks.
Old 11-22-2020, 06:07 PM   #7
JeffB2
JeffB2's Avatar
Originally Posted by 51504bat View Post
Jeff,
Look at the pictures in Post # 5 that should answer your question,over the years guys have swapped to Ford-O-Matic columns to use the AOD in this case he did admit to adding only a very slight bend. This video may help some https://www.youtube.com/watch?v=c6YMP2CqD2I Also save these two part videos. https://www.youtube.com/watch?v=Lod8lHFTKq8&t=123s
Old 11-22-2020, 08:19 PM   #8
paul2748
paul2748's Avatar
If you have a question unrelated to the original, start a new post, don't piggyback
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 11-29-2020, 05:59 PM   #9
hmmech
thanks for all your help, i am going to stay with c-4 trans ,my friend pulled his AOD trans out because of too many high gears for street use, i will not be traveling much on freeways
Old 11-29-2020, 06:20 PM   #10
JeffB2
JeffB2's Avatar
C4 column linkage kit https://www.summitracing.com/parts/l...UaAhIxEALw_wcB
Old 11-29-2020, 06:25 PM   #11
JeffB2
JeffB2's Avatar
"Too many high gears" ? It was shifting too early ? That happens if the rear end ratio is 3:50's or higher numerically EZ fix https://transmissioncenter.net/shop/...d-hirev-79-93/
Old 11-29-2020, 06:53 PM   #12
dmsfrr
dmsfrr's Avatar
His car may have had rear axle gears with lower numbers like 3.10 to 1, or 2.79 to 1.
If he'd like to get rid of the AOD I might be able to force myself to take it off his hands.
Old 12-08-2020, 02:37 PM   #13
hmmech
I paid for this complete rebuilt 302 ford engine from five star engines and he said he would send it with a rear sump oil pan ,that with my c-4 trans and adapter plates from Bitch's Cool Stuff ,hope it all sits in well
Old 12-10-2020, 01:41 AM   #14
JeffB2
JeffB2's Avatar
A recent issue has come up with the donut mounts that Butch's and some other companies use the rubber is now offshore made and they tend to settle in some cases that gets the oil pan too close to the tie rod link. If that happens you can measure the rubber ones and replace or add a polyurethane mount. https://www.energysuspensionparts.co...-isolators.asp
