11-17-2015, 07:59 PM | #41 |
Re: arturos 36
11-17-2015, 08:02 PM | #42 |
Re: arturos 36
Ya, They look like they might be installed on the wrong side. You will know more when you get it apart. Then you can see which way the bigger part of the wheel cylinder is facing and where the longer shoe is located.
11-17-2015, 08:10 PM | #43 |
Re: arturos 36
Hi elturo, Nice old 36 ford. I always feel disappointed when the first things a new owner plans for are a dropped front axle, wide wheels, hot engine etc, etc. The 36 Ford V8 is one of the nicest fords ever built and all those modifications wont improve its looks in my book. The 289 in it would be nice but you have a nice car so why, why, why bugger it up. Heaps of modified ones around but not so many restored or stock looking ones. Think long and hard before you mess it up. Regards, Kevin.
11-17-2015, 08:35 PM | #44 |
Re: arturos 36
Great find. Perfect. Thank you for the heads up !
I need to find out what I need to make them "complete" I have the buckets, rings and lenses. That's it. |
11-18-2015, 12:03 PM | #45 | |
Re: arturos 36
11-19-2015, 09:54 AM | #46 |
Re: arturos 36
11-19-2015, 10:06 AM | #47 |
Re: arturos 36
Not difficult to add the right side taillight if that is something you would want. I think it is much safer to drive with two tail lights and with the addition of turn signals. I would also add a third tail light to the back window. The trim around the back window would be a matter of preference I would think.
11-19-2015, 10:24 AM | #48 |
Re: arturos 36
You need reflectors 48-13028, reflector clips 48-13029, clips to retain the glass lens to the ring 48-13061 and a seal for the reflector to the glass lens A-13066. Since you are not showing the buckets it is hard to tell if you need more. You may need wiring harness for the 2330-6V headlight bulb and the parking light bulb 6V with the proper light bulb sockets 48-13076. The numbers above are from Mac's Catalog.
11-19-2015, 10:40 AM | #49 | |
Re: arturos 36
11-19-2015, 12:00 PM | #50 |
Re: arturos 36
elturo welcome to the barn nice lookin cooop,,,enjoy your restoration, I am glad you are doin it your way!
"I believe God is managing affairs and that He doesn't need any advice from me. With God in Charge, I believe everything will work out for the best in the end. So what is there to worry about". Quote by Henry Ford |
11-19-2015, 01:27 PM | #51 |
Re: arturos 36
For the best info and illustrations of the 35 & 36 in original state buy a COPY OF the 1935-36 FORD BOOK FROM THE EARLY FORD v8 CLUB OF AMERICA! Enjoy!!!
11-19-2015, 05:23 PM | #52 | |
Re: arturos 36
11-20-2015, 10:05 AM | #53 | ||
Re: arturos 36
@Rusk. I found 3 flipper caps! I just need to find 16" rims they'll fit. |
11-21-2015, 05:55 AM | #54 |
Re: arturos 36
I would echo Kens suggestion on the 35-36 book, really great source of information, good illustrations.
I have had it by my bedside since I was given as a present 9 years ago. Good luck with the coupe, even if you go the the overhead route, they will never catch on those new fangled engines! Whatever route you choose I look forward to seeing progress. |
11-23-2015, 10:38 AM | #55 |
Re: arturos 36
I visited with a friend this weekend who builds flat heads. Over several hours, he offered me many ideas & options on which way I could go and should go. So I took the weekend to ponder what I was going to do. The bottom line is, I decided to go with the flat head and ditch the 289 idea. I have already scored a 255 out of a 50' Merc. I'm really trying not to cut up my car so it seems in the long run, the FH is the best way to go. The pictures are a few motors he's built and had at his shop. Thanks again for every ones help and input..
11-23-2015, 11:08 AM | #56 |
Re: arturos 36
Keep the straight axle and avoid the Mustang II temptation.
Mustang II's are for street rods. |
11-23-2015, 11:16 AM | #57 |
Re: arturos 36
Lots of flathead support on the Barn! And it is much more unique and nostalgic than the 289.
11-23-2015, 11:36 AM | #58 |
Re: arturos 36
11-23-2015, 11:54 AM | #59 |
Re: arturos 36
Is this blue shoebox Arturo Arturo?
Congrats on the 36, and the flathead! A different set of gears in the rear, or an overdrive spliced into the torque tube, or an overdrive trans will really help you enjoy that flattie more.
-------------- Drive it like you know how to fix it! DMAFC / OILERS CC-MC |
11-23-2015, 01:16 PM | #60 | |
Re: arturos 36
I know you have all the cool flat head stuff ! I'm sure I'll be picking your brain for your flat head expertise. |
