Guys; We have a '37 water pump that will not stop leaking. We installed a rebuild kit, resurfaced the pump housing and the impeller down to 400 grit paper, still leaks. Replaced the 'square' rings, where the pump housing meets the case housing, still leaks. One time it leaked into the oil pan, believe that is OK now (put air pressure on the cooling system - 7#). However still leaking from behind the pulley. Any one out there knows how to stop this leak ? Tom
