08-23-2020, 08:57 AM | #1 |
46-48 interior panel
I have a 47 Ford club coupe, long door, that other than a couple of pieces of trim didn't come with an interior. The kick panels and door panels should be easy enough to figure out. I just need some help with the panel in the back, how far does it go, where and how does it meet with the headliner etc....If you have pics, or links that would be great to.
08-23-2020, 01:23 PM | #2 |
Re: 46-48 interior panel
This may not help because it is a sedan not a coupe. The headliner material comes down behind the hand strap and behind the gray/blue material. In the old days it was called an ankle strap. John
09-20-2020, 11:00 AM | #3 |
ya boy
08-23-2020, 04:24 PM | #4 |
It definatly points me in the right direction. So there's the cut out for the window, follows, and attaches to the wheel well down to the floor, and then stops just behind the seat seems simple enough
08-23-2020, 07:44 PM | #5 |
I have a pic from my 46 Coupe that I will post later
08-23-2020, 09:19 PM | #6 |
09-01-2020, 01:49 PM | #7 |
would this book have part numbers, and assembly drawings of interior parts?
09-12-2020, 02:43 PM | #8 |
That book would list the part numbers but even then it may be hard to get what you want. At $30 a drawing you want to be sure you are going to get something you can use.
09-13-2020, 02:38 PM | #9 |
$52 at C&G as Item V-44. Sounds pricey, but worth it. 800/266-0470.
09-13-2020, 03:11 PM | #10 |
From Cartouche you can order a complete pre-cut interior panel kit for $319 for those that want to do their own upholstery.
09-19-2020, 10:14 PM | #11 |
I use the EFV8 club book.
09-19-2020, 10:22 PM | #12 |
BTW, my super deluxe without the rear arm rests.
10-14-2020, 04:11 PM | #13 |
So is this what the back panels end up looking like?
10-19-2020, 01:06 AM | #14 |
That looks like it.
