Old 11-18-2023, 04:07 PM   #1
AM3334
Default Remove gas tank.
Do you have to pull the box on 1933 pickup to get gas tank out? Does the filler neck need to be removed to get it out?
AM3334 is offline   Reply With Quote
Old 11-18-2023, 05:32 PM   #2
Vics Stuff
Vics Stuff's Avatar
Default Re: Remove gas tank.
Yes you do need to pull the bed.
The tank sets on top of the
The frame
Vics Stuff is offline   Reply With Quote
Old 11-18-2023, 07:59 PM   #3
AM3334
That means the filler tube has to come off or can it be pulled up with it on after the bed is off.
Old 11-19-2023, 10:57 AM   #4
Vics Stuff
Vics Stuff's Avatar
Yes it does need to be removed as well.
Vic
Old 11-19-2023, 11:39 AM   #5
AM3334
Thanks
