05-13-2019, 09:19 PM | #1 |
Dwell
How do you set the point dwell on a 1949 stock engine?
Sent from my iPhone using Tapatalk |
05-13-2019, 09:41 PM | #2 |
Re: Dwell
Set the points gap at .014-.016" with a feeler gauge by loosening the screws on the points assembly and gently pivoting the breaker points open and closed. You also need to have the distributor lobe at the highest spot on the lobe. Turn the crank pulley with socket wrench (7/8?) Until the points tang is right at the peak of the lobe.
Adjusting the dwell angle and gap independently is not a possibility as I know. Last edited by WABOOM; 05-13-2019 at 09:51 PM. |
05-13-2019, 09:51 PM | #3 |
Re: Dwell
Using a dwell meter hooked up to point contacts , adjust while cranking engine to spec . I believe its 28 degrees.
Understand dwell is a "average" of all eight cam lobes etc and represents the time between lobes the contacts are closed allowing the coil magnetic field to build up for proper firing...... |
05-13-2019, 09:58 PM | #4 |
Re: Dwell
If the gap is correct, what does it mean if the dwell is not in spec.? The lobes are worn?
05-14-2019, 08:34 AM | #5 |
Re: Dwell
If I remember this right. Dwell does not affect timing but timing does affect dwell. I'm sure someone here will correct me if I'm wrong.
05-14-2019, 08:37 AM | #6 |
Re: Dwell
05-14-2019, 08:41 AM | #7 |
Re: Dwell
05-14-2019, 09:40 AM | #8 |
Re: Dwell
05-14-2019, 10:29 AM | #9 |
Re: Dwell
For every degree of dwell, timing is changed two degrees.........
05-14-2019, 11:01 AM | #10 |
Re: Dwell
Ideally, wouldn't you want to set the gap first and the check the dwell/ After that, you could adjust the gap (close it a little to increase dwell and vice versa) to get the dwell to spec. THEN, set the timing. I know it sounds a little finicky, but I'm retired and have a lot of time. Plus, I like to do things like this.
05-14-2019, 11:45 AM | #11 | |
Re: Dwell
05-14-2019, 11:59 AM | #12 |
Re: Dwell
I'm not the OP, but my distributor won't rotate. Is there 2 bolt clamping it down?
05-14-2019, 01:34 PM | #13 | |
Re: Dwell
Might need a little persuasion.
05-14-2019, 01:42 PM | #14 |
Re: Dwell
Ok. I'll persuade it.
05-14-2019, 01:50 PM | #15 |
Re: Dwell
The vacuum line would be the only other factor on a load-o-matic for making the timing adjustment difficult to rotate. If the distributor body is gummed up where it fits into the timing cover then that might also make it difficult. 8BA family engines all just have the same single clamp to hold them down to the head.
If a person sets the point gap on one lobe of the distributor cam, it may not be the same at 90 degrees from the point due to cam lobe wear or distributor bushing or shaft wear. If points don't open enough then the dwell time will be less than spec. If they open too much then dwell time will be more than spec. It's just an average of point opening amounts for all the different lobes. GM distributors with the window and adjustable points could be adjusted while running but most of the older ones, it's just adjust and check by trial and error until it's as close as it will get. Generally, all it takes is to properly set the point gap to specs. If all is in good condition and order, it should have the correct dwell time. |
