11-20-2010, 07:14 AM | #1 |
compression test
did a compresston test on my engine i got 60 pounds on all four cylinders is this good for an a motor or what should it be close to its all stock
11-20-2010, 07:20 AM | #2 |
Re: compression test
Perfect! In fact I will swap you even.
11-20-2010, 07:25 AM | #3 |
Perfect
11-20-2010, 07:28 AM | #4 |
Right on the money for a stock engine. Congratulations!!
11-20-2010, 09:31 AM | #5 |
I got between 54 and 56 on mine and happy to get it. You've got a gooden!
Pete |
11-20-2010, 10:42 AM | #6 |
11-20-2010, 10:56 AM | #7 |
hard starting , use of oil , a cyl fouling a plug , alot of blowby.......... steve
V4f |
11-20-2010, 11:03 AM | #8 | |
Look in Les Andrews' MODEL A FORD TROUBLESHOOTING AND DIAGNOSIS book, (the third volume of his series), which gives a full page on how to perform a compression test on a Model A. He says an "average" Model A engine should have from 55 to 70 psi. |
11-20-2010, 11:52 AM | #9 |
thanks guys i am going for a long drive justenjoying my 28 tudor
11-20-2010, 12:07 PM | #10 |
where in Ontario are you from Mike?
11-20-2010, 01:19 PM | #11 |
60 pounds is good compression for any stock Model A but it's not perfect as others have suggested. Perfect would be closer to 76 pounds. BUT, it's not going to happen unless you have a new old stock, never used original cam.
11-20-2010, 01:30 PM | #12 | |
https://fordbarn.com/forum/showthread...mpression+test Then just for the hell of it, click on the following and read the thread. Predicting gauge pressure, perfect Model A https://fordbarn.com/forum/showthread...mpression+test Last edited by Larry Brumfield; 11-20-2010 at 02:10 PM. |
11-20-2010, 07:39 PM | #13 |
It's not so much the number(PSI) but the variance between cylinders. The number is greatly affected by temperature, oil on the piston rings, and the amount of carbon build up in the combustion chamber. If they are all within a few pounds of each other you are in great shape.
