Old 10-22-2013, 06:54 PM   #1
tmchip
Default 49 Ford F2 flathead
We ( my Dad and I)( ken) own a 20 T touring, 29 & 30 Model A, 37 Lasaille and R restoring a 47 F2 for my sister. we made the mistake of not marking the head bolt heaters when we took it apart to have the block redone. We have searched books but cannot find the answer, since this truck came from MN,ND and will be going to NY state when completed we would like to have them in the correct position if anyone can help it will be greatly appreciated [email protected] or Ken at 334-803-3872 txt me thanks.
tmchip is offline   Reply With Quote
Old 10-22-2013, 07:07 PM   #2
texas webb
Default Re: 49 Ford F2 flathead
Whats a headbolt heater?Pics.
texas webb is offline   Reply With Quote
Old 10-22-2013, 08:48 PM   #3
oldblue
oldblue's Avatar
x2 i'm curious
49 Mercury M68 Pickup
oldblue is offline   Reply With Quote
Old 10-22-2013, 09:18 PM   #4
paleot
If you are talking about the sending units that bolt into the heads the dual connector one goes driver side.
paleot is offline   Reply With Quote
Old 10-22-2013, 09:28 PM   #5
Gary in La.
Gary in La.'s Avatar
A headbolt heater is used in cold weather to warm the engine for easier starting. Our '50 F-2 had one but I don't remember the location. Sorry.
Gary in La. is offline   Reply With Quote
Old 10-22-2013, 10:37 PM   #6
RMR&C
RMR&C's Avatar
I wouldn't think it would matter that much where it is as long as it has clearance on all sides down in the block. Main objective is to warm the coolant. We had on on the old H Farmall tractor.....worked great for years but finally burned out.
For you guys in warmer climes, they are simply a threaded element that replaces a head bolt to warm up the engine on a cold day.
RMR&C is offline   Reply With Quote
Old 10-23-2013, 03:56 AM   #7
51 MERC-CT
51 MERC-CT's Avatar
In as much as most if not all of these were after market items, the positioning was done according to the instructions provided with the units.
As stated, so long as it goes into the water jacket without interference.
Most likely the heaters are really not necessary where the truck is going to, so if it were me I would just not install them.
This is a pic of a similar heater.
Old 10-23-2013, 06:19 AM   #8
34PKUP
34PKUP's Avatar
Yep! unless it's going to be used in an environment where it is absolutely necessary, do not install them.
34PKUP is offline   Reply With Quote
Old 10-23-2013, 06:55 AM   #9
tmchip
I will try to post a pic of it but as someone stated it is rod shaped, about 3/8 diam brass color about 10 in long. It has two elec connector tabs at top encased in bakelight material threaded about 3 1/2 down from top. it will fit in a couple of places on each side of the head and there is one for each side. Thanks for help we will try to get diff bolts for it or put them in last to c where they will fit better.
Old 10-23-2013, 07:45 AM   #10
mtflat
mtflat's Avatar
I don't know where you're located, but I can start my 48 F1 at -20F without a block heater.
When it gets that cold I run a ceramic forced air heater aimed at the dist/carb for faster starts.
If you're determined to use it, I'd say down low and center for even heating
mtflat is offline   Reply With Quote
Thread Tools
Display Modes
