Old 10-22-2013, 02:17 PM   #1
Shadetree
Shadetree's Avatar
Default 1951 F1 Steeriing Box Repair
I have a winter project coming up. I want to rebuild the steering box in my `51 F1. I was lucky when replacing the steering box on my cabriolet, it has an open top and no problem pulling the box from the topside. Does the `51 pickup remove the same way or can it be removed from the bottom without being on a hoist?
Son, you will never blow an engine up in high gear.
Shadetree is offline   Reply With Quote
Old 10-22-2013, 02:51 PM   #2
Vic Piano
Vic Piano's Avatar
Default Re: 1951 F1 Steeriing Box Repair
Bud, I did our '51 ten years ago so I don't remember exactly how we removed the column but I didn't take the body off until after the steering column was out. As I recall, we took the steering wheel off and removed the shift shaft and the column shaft first and unbolted the steering box, etc. and pulled it out but... I had removed the front clip and that made the job much easier. Have fun.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 10-22-2013, 02:58 PM   #3
Ross F-1
Ross F-1's Avatar
Take the pitman arm off, remove the column shifter, wheel, remove floor plates near the pedals, and you can drop it out the bottom or pull it out thru the cab. Only comes out the top if you have stock exhaust, in fact with Red's headers, I don't think it can come out at all with the header in place. It greatly helps to disconnect the pedals so you can flop them down, if pulling out the top.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 10-22-2013, 08:41 PM   #4
oldblue
oldblue's Avatar
You can undo the front motor mounts and shove the motor over to the passenger side to gain enough room to take the steering box out the bottom .
49 Mercury M68 Pickup
oldblue is offline   Reply With Quote
Old 10-22-2013, 08:53 PM   #5
Ken Crans
Ken Crans's Avatar
Shadetree,Straight out the bottom.
Ken Crans is offline   Reply With Quote
Thread Tools
Display Modes
