03-21-2014, 04:02 PM | #1 |
Head gaskets for 239 flathead
I have a 39 Ford flathead and I need to know the best head gaskets to use on it and if possible a part number. My parts guy says FelPro only do head gaskets separate from full sets for 49-53 and that other than that I need to order a full gasket set, which I don't need. Thanks!
03-21-2014, 04:36 PM | #2 |
Re: Head gaskets for 239 flathead
Use a steel or copper gasket coated with coppercoat on both sides. The soft gaskets will be a real pain go get a head loose from if you have to pull the head again. Coppercoat seals well.
03-21-2014, 04:45 PM | #3 |
03-21-2014, 06:45 PM | #4 | |
03-21-2014, 09:13 PM | #5 |
The best gaskets are 'Best" [brand name]. Available individually, from many places including Joblot as above.
03-21-2014, 11:14 PM | #6 |
03-21-2014, 11:41 PM | #7 |
you can also get "Best" brand gaskets at speedway.
03-22-2014, 10:32 AM | #8 |
03-22-2014, 11:31 AM | #9 | |
03-22-2014, 12:12 PM | #10 | |
Be certain to order the correct gaskets. You can get just the head gaskets at NAPA. You may have to speak with a counter person that knows how to look in an actual book vs. the computer.
03-22-2014, 12:34 PM | #11 |
Thanks Folks! I'll see what I can find.
03-22-2014, 04:00 PM | #12 |
Have you tried THE OLD CAR CENTRE in Langley , they should have them but may not be cheap .
49 Mercury M68 Pickup |
03-22-2014, 05:51 PM | #13 |
O'Reillys sells the complete FelPro set for $60, only about $10 more than the head set. I've never had a problem on 8BA's with FelPro.
'52 F-1, EAB flathead |
03-22-2014, 09:49 PM | #14 |
I agree, I have Felpro gaskets on my 49 with no problems. One I even took off and reused shortly after putting it on due to a hairline crack in the top of the head and still no problems.
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. " |
