Old 04-20-2021, 09:37 PM   #1
Rocktrend
Default 39 big truck motor mount removal
First post. Doing frame off on a 39 big truck flathead 8 how do I disassemble the motor mount? Does it thread together from either side of the frame?
Rocktrend is offline   Reply With Quote
Old 04-20-2021, 10:52 PM   #2
cas3
Default Re: 39 big truck motor mount removal
Big bolt from the bottom up thru the water pumps with a cotter pin and nut on top is all it should be. welcome to the barn, lets see the truck !
Old 04-21-2021, 07:36 AM   #3
Rocktrend
It's just so congealed together that I couldn't tell if that's how it came apart. So I just have to pound the old bolt down through the bushing?
Old 04-21-2021, 08:01 AM   #4
alanwoodieman
yes pound down to get out. the rubber grows and it all gets stuck. pictures of your 39?? just have been working on a 39 and 41 and just purchased a 47 1 1/2 ton trucks.
Old 04-28-2021, 10:56 AM   #5
Rocktrend
That green one looks identical to mine. You are my new friend.
Old 04-28-2021, 05:22 PM   #6
Rodrelic
Buddy wanted to do his and he was same age as the truck, born in ‘39. Had bad memories of standing on his head, back in the day to work on them, so I helped engineer and complete a tilt front end. Know it’s sacrilege but there is no hassle doing under the hood stuff.
Rodrelic is offline   Reply With Quote
Old 04-28-2021, 11:03 PM   #7
Newc
Newc's Avatar
I found a 95 hp Merc in my "big truck" 39/40 . take off a head Newc
