Old 10-12-2010, 09:12 PM   #1
Donald-joe
Default carburator problem
I have a zenith carburator 13922 on a 29 model A Ford town sedan that is running too rich and the engine is heating up. How do I adjust the mixture? It doesn't adjust with the choke rod like the originals. Any advice would be appreciated.
Thanks,
Donald Thompson
Donald-joe is offline   Reply With Quote
Old 10-12-2010, 10:12 PM   #2
bogdonj
bogdonj's Avatar
Default Re: carburator problem
Might have to rebuild your carb?
bogdonj is offline   Reply With Quote
Old 10-12-2010, 10:26 PM   #3
steve s
steve s's Avatar
Too rich isn't usually associated with overheating.
The richness adjustment is that little T-valve sticking out the bottom front. Try turning it all the way in, then backing it out 1/2 a turn; that works pretty well on my '29 town sedan. You may need to give it a bit more choke on cold starts, since you've lost that warmup enrichment.
About the overheating, what else did you change besides the carb?
Steve
steve s is offline   Reply With Quote
Old 10-13-2010, 07:53 AM   #4
Jack '29 Sport Coupe
Jack '29 Sport Coupe's Avatar
You might find some answers from the troubleshooting chart
at www.modela.org It's in PDF format and is an excellent reference
guide which you can copy.
Jack
Cincinnati, Ohio
Jack '29 Sport Coupe is offline   Reply With Quote
Old 11-20-2010, 10:23 PM   #5
gtrob2003
Thanks,
Donald Thompson
Donald, did you get your's straightened out? I'm dealing with the same currently. Thanks!
gtrob2003 is offline   Reply With Quote
