03-17-2021, 05:19 PM | #1 |
Water pump grease fitting plug with screw driver slot
I have a NOS 1936 Ford service model water pump that can be used on either side of the engine. It has the grease correct 36 style grease fitting on one side and a brass slotted screw-in plug on the other to close up the open hole. I NEED ONE OF THE SLOTTED SCREW IN PLUGS. I can get one with a hex head or square head at the hardware store, but I'd like to stay original. CAN YOU HELP? Thanks. Old Man Cox. LOL
03-17-2021, 05:52 PM | #2 |
Re: Water pump grease fitting plug with screw driver slot
Ive got a 5 gal bucket of old pumps , Ill check tomorrow.
03-17-2021, 07:01 PM | #3 |
On a model A the same screw is used to close off the oil pressure port ---if you can't find one Brattons or other model A places should have it, or take pipe plug and cut off and make slot
03-17-2021, 08:47 PM | #4 |
A little grinding and a slot you could do in your garage.
03-18-2021, 06:36 AM | #5 |
Only one plug is required since the lube fitting fits into the second hole.
03-18-2021, 08:59 AM | #6 |
Gary [email protected] |
03-18-2021, 04:58 PM | #7 |
I believe the Ford water pump with the lubrication hole on both sided of the pump is a Service Replacement pump and not an assembly line pump. More of NORS made by Ford. Don Rogers posted a Ford print of the Service Replacement pump which has the same Ford part number with a suffix letter of D.
03-18-2021, 05:40 PM | #8 | |
03-18-2021, 05:49 PM | #9 |
the part # 353052-s , I got from 28-37 parts book, same as model A oil passage plug
03-19-2021, 06:57 PM | #10 |
Its on its way . I couldn’t see just that one piece in the box so I took an unusual one that was on a spare 36-37 motor .
Gary |
03-19-2021, 07:32 PM | #11 |
03-22-2021, 03:08 PM | #12 |
Lawson ,did they arrive today . The tracking number is 9405 5036 9930 0316 7645 58
03-22-2021, 03:54 PM | #13 | |
Again, thanks a bunch for your help. What do I owe you? Lawson P.S. I'm glad to see I am not the only one to be plagued with flying small parts syndrome. LOL
03-22-2021, 04:06 PM | #14 |
Just donate the shipping to your animal shelter .
Glad I could help , Gary |
