Old 03-29-2020, 05:20 PM   #1
dmoz
dmoz's Avatar
Default Header Suggestion
Looking for recommendations for headers for a 1950 Mercury that has the stock Flathead and steering/ suspension.
Thanks in advance for your responses.
dmoz is offline   Reply With Quote
Old 03-29-2020, 05:24 PM   #2
petehoovie
petehoovie's Avatar
Default Re: Header Suggestion
Talk to these guys > http://www.reds-headers.com/html/flathead_eng.html
(760) 343-2590
Monday - Friday, 7AM - 3:30PM Pacific Time
(760) 343-2805 Fax
If you would like to order one of our catalogs, please Click Here.
Red's Headers
31-410 Reserve Dr. Suite 4
Thousand Palms, CA 92276
Or contact us via email at [email protected]
Old 03-29-2020, 05:43 PM   #3
51504bat
51504bat's Avatar
Second the recommendation for Red's. I bought all the engine parts from them when I rebuilt the 8ba in my '39 p/u. At the same time a buddy bought headers for his AV8 with an F series steering box. Quality stuff, fair prices, AND they know what the F they are talking about. They won't try to sell you something that isn't right for your application with the "it should fit BS". JMO.
51504bat is online now   Reply With Quote
Old 03-29-2020, 05:58 PM   #4
19Fordy
19Fordy's Avatar
Take a look at what Google search says:
https://www.google.com/search?q=1951...hrome&ie=UTF-8
19Fordy is online now   Reply With Quote
Old 03-29-2020, 06:46 PM   #5
fordv8j
fordv8j's Avatar
We have Reds headers, and exaust system on our 38 coupe, and 38 conv. coupe, they're great
fordv8j is offline   Reply With Quote
Old 03-29-2020, 07:03 PM   #6
CA Victoria
CA Victoria's Avatar
An option,
I used truck manifolds, 1-3/4” pipes with 18” steel packs from Van Pelt.
Sounded great!
I looked at dyno tests that denied any performance gain on a stock engine......the log manifolds are plentiful and relatively inexpensive.
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
Old 03-29-2020, 10:37 PM   #7
slowforty
slowforty's Avatar
Unless you have a Highly modified engine the stock cast iron manifolds work well. This information come from an article by Don Francisco in a 1956 Hot Rod Magazine
slowforty is offline   Reply With Quote
Old 03-29-2020, 10:40 PM   #8
Tinker
Tinker's Avatar
JWLs book says about the same thing. Running dual pipes off the stock would be fine for most of us.
I like "headers" as they get heat off the motor quicker (?) and they sound cool. Prefer fenton cast but in your situation reds. But some say you get a sound off blocking the intake crossover. Different conversation maybe.
If you are looking for performance, and cash is a thing. might be the last thing to think about. Just my opinion. Mill the heads will be better and easy to manage.
Old 03-29-2020, 11:46 PM   #9
aussie merc
aussie merc's Avatar
personally im using fentons its basically stock and the cast keeps the heat out of the eng bay sounds great when used with smithys
aussie merc is offline   Reply With Quote
Old 03-30-2020, 11:23 AM   #10
Ol' Ron
Ol' Ron's Avatar
I like the Fentons as well. Their much quieter in the car and last forever. however. If your looking for an increase in power, Headers and dual exhaust offer little. purley esthetic, but I love the sound..
Old 03-30-2020, 11:29 AM   #11
tubman
tubman's Avatar
I've had Fentons on two cars and really liked them. One thing Ron is correct about is that they will last forever. I pulled an engine in '2016 that had a set of Fentons that I installed in '87. Good as new!
Old 03-30-2020, 12:27 PM   #12
outlaw
I am curious as to why no one offers full length equal tube length headers for flatheads like are used on almost every overhead valve v8 applications. The whole point of headers is to make more power, disperse heat, & help scavenge (pull) the exhaust from the cylinders creating a vacuum helping (in most cases) to pull the next intake charge into the motor. The short cast iron headers don't really do any of this. If you are going to spend the money anyway, why not try to get the most out of it? Just thinkn out loud.
outlaw is offline   Reply With Quote
Old 03-30-2020, 12:50 PM   #13
flatheadmurre
flatheadmurre's Avatar
Flatheads donīt have individual exhaust ports to start with...
With the shared center port things get less perfect...
Old 03-30-2020, 01:35 PM   #14
tubman
tubman's Avatar
By the time the exhaust pulse gets from the valve, through the block, and out the port, it's already seen more restriction than any OHV there is. The shared center port certainly doesn't help, like "Murre" points out.
On the Hemi in my race car, I can see the whole bottom of the valve through the ports; try that on a flathead, especially the exhaust.
Old 03-30-2020, 01:47 PM   #15
petes 50 merc
petes 50 merc's Avatar
i have fenton headers on my merc they are the best
petes 50 merc is offline   Reply With Quote
Old 03-30-2020, 02:15 PM   #16
petehoovie
petehoovie's Avatar
Fenton headers flathead ford
Old 03-30-2020, 04:14 PM   #17
dmoz
dmoz's Avatar
Did you have to do any modifications? I ask because I looked them up and found this:
"Application Note: These headers won't fit most Model Ts or Model As due to narrow the frame width, particularly on the passenger side. 1948-52 Ford F1 (1/2 ton) pick-ups will have interference with one bolt on the stock steering box. That bolt can usually be modified so that the headers can be used. The headers will not work in 3/4 ton or larger trucks from 1948-52. Most 1942-48 Mercury cars will require shimming of the motor mount for steering clearance."
Old 03-30-2020, 04:35 PM   #18
scicala
scicala's Avatar
It doesn't say anything about '49 to '51 Merc's, so I would think they should fit well. The application note just mentions applications that won't work or need modification.
Sal
scicala is offline   Reply With Quote
Old 03-30-2020, 04:37 PM   #19
donald1950
i would personally recommend cast iron headers, like Fenton, as they do not radiate heat like the metal pipe tube headers do. Fentons will help keep under hood temps lower. i found that out when i put tube headers on my '41 pick up....
donald1950 is offline   Reply With Quote
Old 03-30-2020, 08:06 PM   #20
petes 50 merc
fenton headers fit on my 50 merc with no problems been on there at least 30 years
