Old 12-03-2023, 07:42 AM   #21
Big hammer
Default Re: Engine Install
X 2 on the long bolts, when you work by yourself you need all the help you can ! Cut the heads off, grind a taper, cut a slot for a screwdriver for easy removal. Jet engine mechanics install protectors over the mounting bolts and then unscrew them.
get a bigger hammer tap done
Old 12-03-2023, 09:59 AM   #22
Model "A" Fords
Are the protectors on the Jet engine mounting bolts a tool used as guidance for assembly or just protection from damage?
Model "A" Fords is offline   Reply With Quote
Old 12-03-2023, 10:12 AM   #23
alexiskai
alexiskai's Avatar
It's so you don't scratch whatever thing you're sliding into position over the bolts.
Old 12-03-2023, 11:44 AM   #24
JayJay
If you have taps and dies, get some solid rod at your local hardware store or metal supplier and thread about 1/2" of one end, then slot the other end with a cutoff wheel or hacksaw blade. Handy for mounting that 60 lb flywheel as well.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
Old 12-04-2023, 08:09 AM   #25
Smokedtires
Smokedtires's Avatar
I shortened my engine leveler, and made the frame spreader. I had some threaded rod that I cut and ground for the alignment dowels. Splines are marked for visual aid to align transmission shaft.
If all goes well, I will be reinstalling the engine this weekend. Thank you everyone who has helped me get to this point.
Smokedtires is offline   Reply With Quote
Old 12-04-2023, 11:11 AM   #26
katy
katy's Avatar
How long is the "shortened" engine leveler?
Old 12-04-2023, 11:16 AM   #27
alexiskai
alexiskai's Avatar
I'm so proud, I think this is the first time someone has reproduced something I designed.
FWIW I used this leveler and did not need to shorten it.
Old 12-04-2023, 11:27 AM   #28
JayJay
I use that same leveler, exactly. It just clears the firewall and wire box, so I pad them with a towel. But no need to shorten.
JayJay
Old 12-04-2023, 07:07 PM   #29
Smokedtires
[QUOTE=alexiskai;2274297]I'm so proud, I think this is the first time someone has reproduced something I designed.
I can't wait to put it to use this weekend. Thank you for sharing your efforts.
Old 12-04-2023, 07:32 PM   #30
Herb Concord Ca
In the first picture you have a fumaze. Hope you used it while the engine was being stored and not operated. Remove before starting the engine.
Herb Concord Ca is offline   Reply With Quote
Old 12-04-2023, 07:47 PM   #31
goodcar
Originally Posted by JayJay View Post
Put one rear wheel (only one) on a jack stand, and put your transmission in third gear. That way once you get the transmission close you (or your helper) can rotate the tire which will rotate the driveshaft to "clunk" the splines on the transmission input shaft into the clutch disk. Don't forget to lightly grease the transmission input shaft and the nose that fits into the pilot bearing.
Rotating the wheel works but I find it much easier to just put the transmission in neutral.
goodcar is offline   Reply With Quote
Old 12-04-2023, 08:51 PM   #32
Smokedtires
I don't follow, what is a fumaze?
Old 12-05-2023, 06:07 PM   #33
Herb Concord Ca
Sorry Fumaze is a breather on the oil fill tube. Take of the air filter on the carb. The car will run better without it.
