12-02-2023, 05:59 PM | #1 |
Overdrive
This is a picture of the overdrive on the rear axle of my 1931 Deluxe Roadster. It is activated by a lever between the stick shift and emergency brake. Does anyone have any information about it? Thanks!
12-02-2023, 06:40 PM | #2 |
Re: Overdrive
I think that is a Columbia O/D. uses vacuum to operate it. Don't know much about it.
12-02-2023, 07:13 PM | #3 |
Re: Overdrive
BTW, does it work?
12-02-2023, 07:28 PM | #4 |
Re: Overdrive
That looks like Twin-X. Highway Speed 2.84:1, Traffic Speed 3.93:1.
There is a picture at this link. https://www.fordbarn.com/forum/showthread.php?t=176490 Last edited by Bob C; 12-02-2023 at 10:11 PM. |
12-02-2023, 08:05 PM | #5 |
Re: Overdrive
Not Columbia, could be a Twin-X like Bob C says.
12-02-2023, 08:10 PM | #6 |
Re: Overdrive
12-02-2023, 10:56 PM | #7 |
Re: Overdrive
Looks similar to a Ruckstell 2 speed axle for the Model T.
12-03-2023, 01:44 AM | #8 |
Re: Overdrive
There is a shift lever between the stick shift and emergency brake which is pulled back to engage it. (They are connected via a steel rod)
12-03-2023, 01:47 AM | #9 |
Re: Overdrive
It works well, essentially giving you three higher gears when it is engaged.
12-03-2023, 08:50 AM | #10 |
Re: Overdrive
Very curious.
How in the heck does a 2 speed rear end work? When you pull the lever back, what is happening internally to make the gear change? How does it jump from one pinion to the next? |
12-03-2023, 09:48 AM | #11 |
Re: Overdrive
As AzBob said, it looks similar to a Ruckstell which has a planetary gear set in it.
12-03-2023, 05:52 PM | #12 |
Re: Overdrive
Here's an ad from Montgomery Ward Winter sale flyer ending Feb. 28 1929.
I know this is for a T or TT but they may have been made for A and AA as well. I included the whole page just for fun. Jeff |
