01-26-2016, 05:48 PM | #21 | |
Re: Bang!!!
01-26-2016, 06:25 PM | #22 |
Re: Bang!!!
Karl , that sucks !!! Do you need an intake ? I know shipping is a killer but I may have one if you can't find one in NZ.
Cheers Tony |
01-26-2016, 07:36 PM | #23 |
Re: Bang!!!
Awww crap !!
"Came too close to dying to stop living now!" |
01-26-2016, 09:44 PM | #24 |
Re: Bang!!!
Thanks Tony - I have two both Alloy -they look ok but so did the one I had on there. I'm actually ok for parts my main concern is getting the radiator recored properly . Karl
01-27-2016, 07:37 AM | #25 | |
Re: Bang!!!
With the pictures, you can tell that it comes back exactly as it went out. |
01-27-2016, 01:52 PM | #26 |
Re: Bang!!!
01-27-2016, 03:25 PM | #27 |
Re: Bang!!!
Thanks Ted -I've removed the coil and have epoxied up what fragments I could find and will epoxy in the gaps. It appears that when Skip does his coils he coats them in a pink rubber compound which is still intact apart from a minor nick So coil should be ok as a spare. The tip on the frame sounds a good idea-Karl
01-28-2016, 11:45 AM | #28 |
Re: Bang!!!
looking at your photos Karle it looks like you had a out of balance fan or generator .because of the fresh brake .Ted
01-28-2016, 03:22 PM | #29 |
Re: Bang!!!
Wow, that's bad luck. I have had around two dozen flatheads, and have never seen a manifold fail like that. I've also never seen a gennie sitting on the manifold. Methinks a longer belt is needed.
01-28-2016, 03:46 PM | #30 |
Re: Bang!!!
Ted- looking at the fan It would appear that the first insult was it threw a blade and the resulting vibration broke the manifold - I wonder looking at the hub if half the fracture line is old but missed any crack on my pre-trip inspection. My replacement fan is currently being crack tested before I use it.
Bassman -The fan belt was replaced recently. It came from one of the parts houses and was sold as the correct fan belt for a 34 with the correct 40- part number and Ford Logo. However it was tight I still had the inch play in it but the generator was as low as it would go to achieve this. I'm sure the fan belt contributed to things. I have since been told that the fan belt sold is to small but they keep selling them!!! I have since got this forums recommended Gates belt (which when checked is a much better size) and this will go on now. Still planning to get to Art Deco -So hope to catch up with you there -Karl |
01-28-2016, 09:26 PM | #31 | |
Re: Bang!!!
01-28-2016, 11:18 PM | #32 |
MEMBER EMERITUS
Re: Bang!!!
You might want to talk to Allan Tutt at Trevor French radiators Otahuhu.
Tel 09 276 9442 Their prices seemed pretty reasonable when I spoke to them a while back. They advertise in Petrolhead magazine. Page 82 in the latest issue. |
01-29-2016, 04:20 PM | #33 |
Re: Bang!!!
Hi all; Recently I searched out a '34 manifold for a customer [his was cracked at the gen mount] it is a weak point in the early 2 barrel manifolds. The mount casting is hollow on the underside. Possible reinforcing maybe an idea, when not visible. Newc
09-20-2023, 11:52 AM | #34 |
Re: Bang!!!
Yikes!
09-21-2023, 03:44 AM | #35 |
Re: Bang!!!
deleted, sorry....
-WANTED-
Pre-War Speed Equipment Davies or Morrison Intake Manifold 77-6050B, 81AS - 81SB - 99AS - 99SB 19AS cylinder heads |
09-21-2023, 11:02 AM | #36 |
Re: Bang!!!
My 33 threw the fan blade out through the hood side! Newc
