Old 03-18-2012, 03:13 PM   #1
IndyFordy
IndyFordy's Avatar
Default 1935 1936 Windshield frame
City: Indianapolis
State: IN
Price: $200
Solid frame no rust out. has one area with slight dip. comes with hinges and regulator. Not for sure if it is car or truck or if it matters.
IndyFordy is offline   Reply With Quote
Old 03-18-2012, 06:59 PM   #2
john young
Default Re: 1935 1936 Windshield frame
I am needing a frame for a 36 Ford truck but have already bought one that ended up being from a car and they will not work. You have any idea what your frame came off? I am interested.
john young is offline   Reply With Quote
Old 03-19-2012, 07:46 AM   #3
Sid the Maineiac
Sid the Maineiac's Avatar
What are the measurements at center both ways? I believe the truck is narrower in both directions than the car.Someone correct me if I'm wrong.
Sid the Maineiac is offline   Reply With Quote
Old 03-19-2012, 10:31 AM   #4
35 rancho
35 rancho's Avatar
OK ya got me thinking about the frames ? I have both a 35 truck and a sedan The tape measure said the sedan has 44 3/8" wide and 14 5/8 tall,,, the truck measures 45 1/4" wide and 15 1/8" tall. Now I'm not posivtive the truck is correct. After cleaning and repairing and plating the truck frame its weak and fraigle and leaks in rain and at the car wash. But I'm suprised about the diffrence. Hope this helps.
35 rancho is offline   Reply With Quote
Old 03-19-2012, 09:10 PM   #5
Lawson Cox
Lawson Cox's Avatar
Yes, 35-36 W/S frames are same for trucks, but will not work on sedans. Regulator will be same on both
Old 03-20-2012, 06:46 AM   #6
ken ct
The truck is higher in the middle up + down,didn't know about the width across. ken ct.
ken ct is offline   Reply With Quote
Old 03-28-2012, 04:24 PM   #7
IndyFordy
IndyFordy's Avatar
btt
Old 04-15-2012, 08:40 PM   #8
IndyFordy
IndyFordy's Avatar
Btt
Old 04-17-2012, 07:21 AM   #9
36ford
36ford's Avatar
My 36 truck measures 45" across at seam and 15 1/2" at middle do you know what your is??
36ford is offline   Reply With Quote
