05-15-2021, 12:26 PM | #1 |
Valve lifter bore wear
What is the acceptable valve lifter bore wear (59a Block)?
Inserting new lifters they have a noticeable side to side rock, this can’t be ok for the cam? Using a valve grinding stem as a gauge some bores are tighter than others. Are oversized lifters available? Thanks!
Tim Downtown, Ca |
05-15-2021, 02:41 PM | #2 | |
Re: Valve lifter bore wear
05-15-2021, 03:21 PM | #3 |
Never heard of an oversize flathead lifter. I can only speak for myself I have never come across a flathead block that had a worn lifter bore. Have you compared the diameter of the lifters to any others just to determine if they might be a bit smaller in diameter? If I read your post correctly you mention some bores are tighter than others if its possible to try original lifters is that still the situation?
On some of my race flathead blocks I use bronze lifter bore bushings which are only a few thousands in diameter larger diameter than the original Ford lifter bore diameter. These new bushings have a smaller inside diameter for the now smaller diameter lifters. To fix a worn flathead lifter bore so the ID is now back to the stock diameter it would be extremely difficult to do in the block. The reaming operation needed to open the existing worn bore would require a larger diameter reamer. Due to the valve guide bore diameter a larger diameter reamer cannot be used for the bushing boring operation from the top. Also the operation needs to be extremely accurate so the lifter bore is still straight. One company BHJ makes tooling for lifter bore bushing operations as seen in V8COOPMANS post above the operation is rather simple to do with there tooling when there's nothing in the way above the bore. Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH Last edited by Ronnieroadster; 05-15-2021 at 03:30 PM. |
05-15-2021, 03:36 PM | #4 |
My experience (limited) is that they tend to be on the tight side, rather than loose.
05-15-2021, 04:45 PM | #5 |
Same here.
05-15-2021, 06:52 PM | #6 |
I have not found the factory specs for lifter fit, still looking for a bore gauge to measure a small bore with. The adjustable lifters I have are NOS Sealed Power, they measure at .985. What do your lifters measure?
Tim Downtown, Ca |
05-15-2021, 08:58 PM | #7 | |
05-15-2021, 09:38 PM | #8 |
The new Highlift Johnson solid adjustables (PN.2032) I have measure (.9995)
Suspect the ones you have are undersise.
05-15-2021, 10:47 PM | #9 |
I re measured with my new caliper and have the same measurement (added: as post 7 & 8).
With limited options to save a block any thoughts on options? (Added: I’m getting .995)
Tim Downtown, Ca Last edited by CA Victoria; 05-16-2021 at 05:01 AM. |
05-16-2021, 07:39 AM | #10 | |
Hi, Tim If you're getting .995 when you measure, your lifters are .005 smaller in diameter than the .999 ( I dropped the "5" from .9995 for clarity sake) the others have mentioned. Is this maybe the problem? Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick) '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" 302 |
05-16-2021, 09:36 AM | #11 |
Just checked a new set of adjustable lifters I recently bought from Van Pelts. The lifters measure .9995 on the money and are a nice snug fit in my 8BA block
05-15-2021, 10:53 PM | #12 |
Sounds like you need a new set of lifters. Look at it this way : they're a lot cheaper than a new block.
05-16-2021, 12:54 AM | #13 | ||
If so the remedy should be obvious.
05-16-2021, 09:40 AM | #14 |
I would say your new lifters were miss machined or not for a flathead Ford.
05-18-2021, 05:23 AM | #15 |
The Ford blueprint spells out maximum manufacturing machined diameter of 1.0015. However, the wear limit as listed in the original Ford V8 Engine repair manual is listed as .005 clearance between lifter(pushrod) and lifter bore.
There is no practical limit for machining lifter bores oversize and certainly the valve guide bore diameter does not offer an obstacle. Although the oversize boring operation and subsequent bushing treatment process would be more expensive than the average cylinder block could be valued at. |
