09-28-2021, 02:27 AM | #21 |
Re: Crimp style connector/wiring question
Yes, with all the shaking going on the little balls can be sucked in to the carby turning the corn gas into leaded.
09-28-2021, 09:19 AM | #22 |
Slight change of topic - when two bullet connectors have to be joined by the taillight and the bullets are inserted into the double female connector, do they get crimped, soldered or just friction fit?
Thanks |
09-28-2021, 09:29 AM | #23 |
Soldered stranded wire tends to break at the joint without strain relief. Solid wire won't crimp and must be soldered. It won't break unless nicked while stripping.
I prefer solder myself; for stranded wire I use heat shrink tubing over the joint to provide strain relief to the wire. |
09-28-2021, 07:26 PM | #24 |
I crimp the connection with pliers to hold the wire in place while I solder the joint. Remember to put the shrink tubing on the wire BEFORE soldering and slide it far enough away from the heat so it does not pre-shrink in the wrong place.
09-28-2021, 07:50 PM | #25 |
38 year old crimped connectors. No solder. Still going strong.
That's a lot of connections without a single failure. |
09-28-2021, 07:53 PM | #26 | |
09-28-2021, 07:56 PM | #27 |
I crimp then use marine shrink tubing, the kind with glue inside. Makes a nice waterproof connection.
09-28-2021, 08:17 PM | #28 |
Here's a nice ratcheting one from Klein for less $$
https://www.homedepot.com/p/Klein-To...5CR/306884697? |
09-29-2021, 08:49 AM | #29 |
09-29-2021, 03:47 PM | #30 |
Are not new cars all crimped? The only connectors I solder are the original Model A bullet type, only because there is not enough room to crimp.
My brother tells me that the airline industry only uses crimped connectors also.
Ruth "Sometimes you really DO need to read the whole thread" |
09-29-2021, 06:57 PM | #31 |
Go out to your shop and crimp a wire connector. Give it your best shot. Then cut it in half and sand the cut end to form a good cross section. Then compare it with the photo below.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 09-30-2021 at 06:11 AM. |
09-29-2021, 07:41 PM | #32 |
09-30-2021, 06:18 AM | #33 |
Copper wires on boats can be a big headache. Older boats that had non marine grade wires installed need to be re wired with the tin plated marine grade wires. I know first hand, as I suspect Mr. Moose does too.
09-30-2021, 09:39 AM | #34 |
Most of the old original flag and straight connectors weren't designed like modern crimp terminals and many of the new bullet type connectors aren't either. If a person uses these types they have to tighten the joint in a crimping fashion as well as possible and then solder them. In the case of the bullet types, they have to be soldered or they will break. Ford likely soldered them back in the day.
