03-30-2019, 03:06 PM | #1 |
Coolant Seep on Head
Noticed a minor pool of coolant around one of the center head studs. Rechecked the torque on all the nuts and had no take up. Do the studs thread into the water jacket or just threaded blind holes ? Not getting any coolant into the combustion chambers. Think I'll try some stop-leak before entertaining pulling the head. Watcha think ?
03-30-2019, 04:04 PM | #2 |
Re: Coolant Seep on Head
Your referring to wet holes and dry holes. The answer is Yes, some dry and some are wet. Best practice is to coat the stud bottom thread with permatex#2 sealer when assembling. If any coolant is getting into a cylinder, that can cause your idle issue.
03-30-2019, 04:08 PM | #3 |
need more info,rebuilt engine? stock head? stud torque? checked torque when engine is hot?on going problem or recent occurrence?
03-30-2019, 08:17 PM | #4 | |
03-30-2019, 10:22 PM | #5 | |
04-01-2019, 06:55 PM | #6 | |
