04-09-2022, 09:08 PM | #1 |
Weight of 60HP engine w/transmission
Can anyone give me the approximate weight of a 60HP engine and transmission combination? I do not have access to that info. I'm figuring close to 700lbs. How far off am I? Thanks. Lawson
04-10-2022, 03:38 PM | #2 |
MEMBER EMERITUS
Re: Weight of 60HP engine w/transmission
390 lbs
04-10-2022, 04:38 PM | #3 |
Still too heavy to lift by yourself Lawason. You might hurt yourself.
04-10-2022, 06:20 PM | #4 |
Source of your information, please. I discovered Ford stated 300 pounds on just engine.
04-10-2022, 06:21 PM | #5 |
[QUOTE=Jack E/NJ;2120191]Still too heavy to lift by yourself Lawason. You might hurt yourself.[/QUOTE
Yep. Hernias are no fun.
04-10-2022, 07:12 PM | #6 | |
I don't KNOW this to be a fact, but the 300 lbs. figure MAY be WITHOUT flywheel, pressure plate, clutch disc and generator. GM had a habit of listing engine weights that way back in the '50s and '60s. Coop . |
04-11-2022, 07:06 AM | #7 |
I knew a guy who carried a "bare block" down to his basement by himself in the 60s. He was a big fella but not real muscular.
04-11-2022, 10:33 AM | #8 |
Yeah, but did he carry it back UP the stairs?
https://www.nirgv8.org |
04-11-2022, 02:25 PM | #9 |
I along with a friend easily carried a stock V-8 sixty including the complete flywheel assembly from the top of a file cabinet where it was being stored into the back of a pickup and them out of the truck once I got home. Doubt we were lifting 300 pounds BUT I was a bit young at the time.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
