04-13-2012, 11:19 AM | #1 |
Tightening spring clips. How tight?
Just snapped one of my spring clip bolts reassembling spring. I noticed the nut and bolt were not hardened bolts so my question is how tight should they be and should I buynew hardened bolts. Also should I use a lock washer?
Thanks guys! |
04-13-2012, 07:31 PM | #2 |
Re: Tightening spring clips. How tight?
snug enough so they don't rattle, 1/4-20x2 3/8 with square nut. Judging stds show no washers.
www.whidbeymodelaclub.com |
04-13-2012, 08:46 PM | #3 |
put the stick on weights on the inside part of the rim. or install dyna beads inside the rim
04-13-2012, 08:58 PM | #4 |
o crap ment to post this on a dif. thread ^
04-14-2012, 09:19 AM | #5 |
