01-01-2017, 08:48 PM | #1 |
How much paint
How much paint is required to paint 6 wheels? I have 1/2 gallon of the paint I want to use but don't want to run short. It's s custom mix that I can't get in a short time frame if I do run short.
01-01-2017, 09:54 PM | #2 |
Re: How much paint
how will a response change your decision. Your going to use the paint no matter what. Do the spare(s) last. Wayne
01-01-2017, 10:06 PM | #3 |
Re: How much paint
Depends what type of paint .lacquer, enamel,BC/CC, urethane as well as what style paint gun you are using such as a gravity HPLV or an old school siphon Binks type gun. Need more specifics...
01-01-2017, 10:53 PM | #4 |
Re: How much paint
Yup. And are you going to be adding paint additives and how many coats also.
01-02-2017, 10:02 AM | #5 |
Re: How much paint
Do not forget,
How many bugs are out that day, how good are you at painting, and such. This coming from someone who is not very good at painting. |
01-02-2017, 12:04 PM | #6 |
Re: How much paint
01-02-2017, 03:50 PM | #7 |
Re: How much paint
Endura paint (polyurethane) sprayed with a small touch-up gravity HVLP gun, two coats for sure, likely 3.
01-02-2017, 04:08 PM | #8 |
Re: How much paint
All steel from pedal to wheel |
01-02-2017, 04:21 PM | #9 | |
Re: How much paint
01-02-2017, 04:23 PM | #10 |
Re: How much paint
used 1/2 gallon of acryl enamel to paint 5 wheels years back; thinned with solvent reducer approx. 1:1 . was barely enough to get desired coverage over primer even with the reducer + hardener ; also need some for re touch if scratched
01-02-2017, 04:25 PM | #11 |
Re: How much paint
How many coats did you have enough for??. Some paints cover better than others.
01-02-2017, 04:39 PM | #12 |
Re: How much paint
my recollection is 2 wet coats of Vermillion, minimized on the spokes and maximized on the hub area and front of rim using a siphon gun. again this was thinned acrylic enamel before urethanes / activators became popular
01-02-2017, 04:48 PM | #13 |
Re: How much paint
Hmmmm. I need to do 6 wheels (actually 16" 1935 wheels) and would like 3 coats. I figure that by using the small touch-up gun and narrowing the pattern, I will get more paint ON the wheel and less going PAST the wheel which would help the paint go further but not THAT much further.
01-02-2017, 05:02 PM | #14 |
Re: How much paint
Have you tried the water transfer painting method? It would take a lot less paint.
Here is a link to a youtube video on how to do it. They use a decal pattern but you can just pour straight paint onto the water instead. Practice a few times on spare parts. https://www.youtube.com/watch?v=X86uAWWZHi0 |
01-03-2017, 11:57 AM | #15 | |
Re: How much paint
01-03-2017, 01:01 PM | #16 |
Re: How much paint
LTK, your avatar is priceless!
01-03-2017, 01:26 PM | #17 |
Re: How much paint
01-03-2017, 02:07 PM | #18 | |
Re: How much paint
Happy New Year Last edited by Mitch//pa; 01-03-2017 at 02:36 PM. |
01-03-2017, 05:14 PM | #19 |
Re: How much paint
half gallon should be fine for at least three coats.
