12-20-2022, 03:45 PM | #1 |
Electronic turn signals and LEDs
Howdy boys, a question on LED's. I just installed LED's for front turn signals, I have had them in the rear for several years, and have no other source to draw power other than the small BEEP'er for the electronic signals. Without activating the blinkers, I get a continuous beeeeeeeeeepp from the unit. I am assuming it is because I have no LED flasher installed. It acted the same with a regular 6 volt flasher (Beeeeeeeppp). I am at somewhat of a loss on where to find an LED flasher, other than one of the vendors. I hate to pay $30 for a flasher, and $15 for shipping if I can avoid it. Anybody have a part number for them? I'm stock, 6 volt +ground. Thanks guys!
12-20-2022, 05:29 PM | #2 |
Re: Electronic turn signals and LEDs
You can add a resister to the circuit that will pull more current needed to operate the flasher.
I have turn signals on my Victoria that is six volt positive ground. I have LED lights for the stop lights, and use the cowl lights for the front turn signals. I put the higher wattage incandescent bulbs from Bratton's in the cowl lights to pull the extra current needed to operate the flasher. Tom Endy |
12-20-2022, 06:30 PM | #3 |
Thanks Tom, I've considered that, but I have LED's at both ends. I know there is a flasher out there, just have to find it.
12-20-2022, 07:24 PM | #4 |
This is the flasher I found on Amazon 5-6 years ago and it works great for LED's.............
AL in NY |
12-20-2022, 07:29 PM | #5 |
Ebay - $6 free shipping https://www.ebay.com/itm/124209342725?hash=item1ceb742905:gKgAAOSwc5pdX5h A&amdata=enc%3AAQAHAAAA8PQX%2BqjuxcBhfey%2FJ%2FJns YCM6mMrDmGQW04pPtt9KiHWvNhVmEwa3e7%2FaPiHOKN9Honk6 7n5JQi3bP4M0H1DrOmsJ5lVeOH8GWtDZcgJBSIuOSb7JDMnlo4 1pERO1YPWjK33DQSCxybeVlqfbk0ZD7kvSRBC2F3TounI5qzes 5p6ALQ7j6xEk7AeIRqlG8oQ8Gdx7%2FYrNFgB7NwvbnoqeiSgZ TrSzUle0tlD%2FDFRTTzSFpXtwT7oevmn8k9oI%2Ff3G6Fx8HG UF8ai5eFwaY76d7EkRjKqcLfUmKrtUm%2F6VbYns5u7tR1N12S kZsEPEt7Blg%3D%3D%7Ctkp%3ABk9SR9C5kqGmYQ
$21 if you need 6v https://www.ebay.com/itm/13363298962...Bk9SR-6AuqGmYQ I just ordered some LEDs a flasher & switch (about $30). I think my 12v converter is enough to run my GPS and signals if not it'll be another $5-10. |
12-20-2022, 07:47 PM | #6 |
https://www.ledlight.com/flasher-6-v...e-chassis.aspx |
12-20-2022, 11:53 PM | #7 |
Al in NY, are you 6 volt, + ground? Did you ground the wire? Thanks!
12-21-2022, 01:04 AM | #8 |
I tried the 12v version of the one shown in post #4. Worked perfectly -- until I started the engine. Then it went haywire. Ended up putting the old one back in.
12-21-2022, 09:00 AM | #9 |
I have been using a turn signal control unit in my antique vehicles made buy Turn Signals For Classics for more than 10 years. Their USA made control works perfect, is compact, and provides all the functions needed for LED turn signals, LED brake lights, and assessory LED lights. The control is available in 2 versions, 6 volt (+or-) or 12 volt (+or-). You can use a column mounted turn lever or a hidden momentary switch for turn signaling.
The control has the following functions: turn signaling with adjustable on-time, turn signal remains on while brake is applied, brake light, emergency flasher, assessory lights i.e. cowl lights, on or off beeping. LED resistors and special LED flashers are not required. This unit is truly a plug-n-play device and cost $84. I have my unit velcro mount to the drivers side panel behind the kick panel. I have a momentary switch mounted to the left of the steering column and hidden behind the dash panel. See http://turnsignalsforclassics.com |
12-21-2022, 02:59 PM | #10 |
Seabees: I have a 6 volt positive ground system. And yes I did ground the pigtail wire (ground being +6volts).
AL in NY |
12-21-2022, 05:14 PM | #11 |
If you can't find a flasher locally, you will need to add load resistors, one to each side. I used two 2 ohm 40 Watt resistors, which I had on hand. Wire them into the front turn LEDs one on each side and connect to ground.
12-22-2022, 08:44 AM | #12 |
Using resistors works but can be a pain as it involves wiring them into the circuit and also can depending on the load create additional heat. The control I am using as noted in post #9 above eliminates the need to use resistors and special solid state flashers.
