12-12-2021, 02:23 AM | #1 |
Modern tubes
This is a new wheel barrow tube. Quite expensive, and very thick rubber. However, on fiirst use it went flat. I repaired pin hole with a bicycle patch, put it back on, and it went flat again.
Pulling off the patch, it had split along the seam line a bit like others have reported here on car tubes. |
12-12-2021, 03:27 AM | #2 |
Re: Modern tubes
I don't think manufacturers have much interest in tubes any more.
12-12-2021, 08:34 AM | #3 |
Re: Modern tubes
Great!!
The Master Cylinder Enjoying life at the beach in SoCal... |
12-12-2021, 08:38 AM | #4 |
Re: Modern tubes
I went to solid wheels on my wheelbarrows. I think they are filled with foam rubber.
12-13-2021, 02:33 AM | #5 |
Re: Modern tubes
I've now got a "Freedom" tube from China.
That'll work for sure. . |
12-13-2021, 09:55 AM | #6 |
Re: Modern tubes
12-13-2021, 11:25 AM | #7 | |
Re: Modern tubes
