Old 02-10-2017, 02:06 PM   #1
JDupuis
JDupuis's Avatar
Default Well worn parts
Thought I'd post this picture of a well loved pulley. Came off my 30 farm/barn car. I will never use this part again, but I don't want to scrap it either.
Great conversation starter.
Anyone else with pic's to share?
Let's let pylons, be pylons!
JDupuis is offline   Reply With Quote
Old 02-10-2017, 02:09 PM   #2
Marshall V. Daut
Default Re: Well worn parts
"All's weld that ends weld."
Ow! Ow! Ow!
Marshall
Old 02-10-2017, 02:33 PM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Looks like MY BODY scars! If they were TATOO's, I'd look like FRANKENSTEIN's BROTHER.
Bill Damaged
"THE ASSISTANT GURU OF STUFF"
Old 02-10-2017, 03:17 PM   #4
H. L. Chauvin
I still have a poorly brazed wobbly crankshaft pulley that came with my $25.00 Model A Coupe that I purchased in 1958.
It wobbled so much the former owner had a wood wedge between the generator and the engine to keep the belt tight.
Just a symbol and sign of the times when 55 years ago so many Model A's in our area were owned by Americans living in poverty .... former owner had no indoor plumbing and his wife cooked with a used kerosene stove ..... he & his wife were cultivating their garden with this coupe the day that I bought it.
H. L. Chauvin is offline   Reply With Quote
Old 02-10-2017, 03:36 PM   #5
Ray64
Ray64's Avatar
Great wall art
Ray64 is offline   Reply With Quote
Old 02-10-2017, 03:39 PM   #6
Tom Endy
Tom Endy's Avatar
Transmission case removed from a running car.
Tom Endy
Tom Endy is offline   Reply With Quote
Old 02-10-2017, 03:51 PM   #7
JDupuis
JDupuis's Avatar
Worn clam shell.
Old 02-10-2017, 03:53 PM   #8
H. L. Chauvin
Hi J,
The two (2) side door glasses on my 1930 coupe were "well worn" also in 1958, where they rubbed and contacted the two (2) side window glass channels.
Think I still have them ........ the factory paint wore off of these two makeshift side glasses ..... the side glasses were really an advertisement when rolled up ...... both were made from two metal RC Cola Signs ..... never needed tinted glass.
Now that I think about it, this modern improvement greatly helped with 90 degree inside glass reflections while driving at night.
Old 02-10-2017, 04:11 PM   #9
Tom Endy
Tom Endy's Avatar
The banjo in the photo came out of a 28 phaeton that was brought up from Argentina. It was a running car. The banjo is the early version without support gussets. It had apparently cracked in a number of places. The repair was to weld rebar around the flange collar in addition to other weld supports.
Tom Endy
Old 02-10-2017, 04:21 PM   #10
Tom Wesenberg
Tom Wesenberg's Avatar
Tom Endy
Now, that's one to hang on the "Wall of Desperation".
In 1995 I looked at a 1929 pickup that came from South America, but it was so beat up and patched up and still had cracks all over, that I wasn't interested in it. It did sell though for just over $5000.
Old 02-10-2017, 04:40 PM   #11
rocket1
They could use that pulley in cuba!
rocket1 is offline   Reply With Quote
Old 02-10-2017, 04:43 PM   #12
Tom Endy
Tom Endy's Avatar
The carrier half in the photo came out of a running car. The owner wanted the rear axle\differential overhauled. When the axle assembly was removed the sheared hub containing the bearing fell off. The car had been operating with the hub sheared.
My theory is that a mechanic of yesteryear bolted the axle housings to the banjo without any thought to pre-load. The carrier was probably locked. Usually it spins the bearing on the hub. In this case it was probably locked so tight it sheared the hub off the carrier.
Tom Endy
Old 02-10-2017, 05:25 PM   #13
JDupuis
JDupuis's Avatar
Great pictures Tom. Although I don't have pictures, the rear end of my barn car, had the roller bearing on the pinion fail.. The rollers smashed around the inside of the banjo and meshed with the gears. When they looked into doing the repair, they bent the roller cage so no more rollers would fall out and put it back together. There were hairline cracks in the banjo and chunks out of the gears. This is the same car that the pulley is from. Jeff
Old 02-10-2017, 07:41 PM   #14
Tom Endy
Tom Endy's Avatar
The attached ring & pinion came out of a "was" running car. The new owner was resurrecting it from a barn find and got it running. On a "short" drive around the neighborhood the rear seized up. There was no oil in the banjo.
Tom Endy
Old 02-10-2017, 09:04 PM   #15
updraught
updraught's Avatar
... When the axle assembly was removed the sheared hub containing the bearing fell off. The car had been operating with the hub sheared.
Tom Endy
Found the same thing. Unrestored diff, seemed to be low mileage. Everything inside in good condition. Just the carrier broken.
updraught is offline   Reply With Quote
Old 02-10-2017, 09:23 PM   #16
Synchro909
Synchro909's Avatar
Tom Endy
I had a car come to me after being serviced by a modern Ford dealer in AZ. One of the many things they stuffed up was, you guessed it - no oil in the diff. Luckily, it hadn't done many miles that way and I saved it but its life will have been shortened.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 02-11-2017, 12:53 AM   #17
3.6rs
3.6rs's Avatar
Water pump and brake rod out of my Tudor.
3.6rs is offline   Reply With Quote
Old 02-11-2017, 11:09 AM   #18
Kurt in NJ
Kurt in NJ's Avatar
I did some work on a fresh purchase car, the guy that bought it said (bought not running) "It just had a brake job, that should be good", it had new linings, fresh turned drums, something like .185 over, the drum was less than .020 thick in places----figured I could cut it into point setting feeler gauges----"real ford feeler gauges"
Old 02-11-2017, 01:00 PM   #19
1955cj5
1955cj5's Avatar
This was the rear crossmember in my ccpu.....been there for many many years, but I finally replaced it...can't bring myself to throw it out though!
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
