Old 06-27-2022, 01:37 PM   #1
CC-Mo
CC-Mo's Avatar
Default Where to find 46-47 tailshaft assy?
Looking for a 46-47 Ford pickup tailshaft assy with yoke.
Been hitting the vendors with no luck. Any suggestions?
Thanks guys.
Southern Missouri
'30 Tudor sedan, Original
'33 5-Widow Coupe, Henry Steel, Merc Flathead, 50's Hotrod style.
CC-Mo is offline   Reply With Quote
Old 06-27-2022, 01:47 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: Where to find 46-47 tailshaft assy?
Thanks guys.
They show-up here in the "SWAP MEET" section on occasion, as well as eBay, etc. But Mac VanPelt (click on the link BELOW) is a long-time FordBarn member and expert on these old Ford transmissions. He has a huge inventory of new/used parts and has a rebuilding service, also. Call and ask for Mac. Coop
http://www.vanpeltsales.com/FH_web/flathead_home.htm
Click Links Below __
T5 W/TORQUE TUBE
Old 06-27-2022, 01:59 PM   #3
CC-Mo
CC-Mo's Avatar
Thankyou Sir! I’ll give him a look.
Southern Missouri
Old 06-27-2022, 02:35 PM   #4
deuce lover
deuce lover's Avatar
Here.He also has the main shaft in another auction
https://www.ebay.com/itm/15500434299...kAAOSwOXliqlG7
https://www.ebay.com/itm/15500434232...YAAOSwCX5iMHNm
Old 06-27-2022, 02:45 PM   #5
cas3
Are you talking about the output shaft in the trans, or a drive shaft?
Old 06-27-2022, 02:53 PM   #6
deuce lover
He did not mention the driveshaft.Just the tail shaft assy and yoke so I posted what I saw on EBAY.
Old 06-27-2022, 03:05 PM   #7
V8COOPMAN
V8COOPMAN's Avatar
An "OUTPUT" shaft is technically called a "MAIN SHAFT"....the same shaft that the yoke slides onto. Coop
T5 W/TORQUE TUBE
Old 06-27-2022, 03:05 PM   #8
CC-Mo
CC-Mo's Avatar
The trans output shaft is what I’m hunting for.
Southern Missouri
Old 06-27-2022, 03:06 PM   #9
CC-Mo
CC-Mo's Avatar
I’ve got a call in to vanpelt. Waiting on a callback. Thanks again.
Southern Missouri
Old 06-27-2022, 03:12 PM   #10
V8COOPMAN
V8COOPMAN's Avatar
Those YOKES have become extremely hard to find. It's been said that an early, cast-iron Powerglide yoke (16-spline) will fit, but no guarantees on that one. Coop
T5 W/TORQUE TUBE
Old 06-27-2022, 03:13 PM   #11
CC-Mo
CC-Mo's Avatar
The application is going from a ‘39 trans to a 9” rear. It’s in a ‘33 coupe.
The eBay link posted above looks like the goods.
Wishful thinking but it’d be nice to find a complete adapter & shaft, yoke, seals & all.
If not, I can piece it together.
Southern Missouri
Old 06-27-2022, 03:25 PM   #12
V8COOPMAN
V8COOPMAN's Avatar
Mac (Mac VanPelt) is likely going to be the only source that MIGHT be able to supply you with a complete package like that. Coop
T5 W/TORQUE TUBE
Old 06-27-2022, 03:28 PM   #13
bbrocksr
I've got the whole works less the yoke.
Bill
bbrocksr is offline   Reply With Quote
Old 06-27-2022, 03:30 PM   #14
CC-Mo
CC-Mo's Avatar
Bill
I’ll keep you in mind also & thanks!
Southern Missouri
Old 06-27-2022, 03:31 PM   #15
oldskool
oldskool's Avatar
is the trans a 3 or 4 speed?
oldskool is offline   Reply With Quote
Old 06-27-2022, 03:43 PM   #16
CC-Mo
CC-Mo's Avatar
It’s a 3 speed
Southern Missouri
Old 06-27-2022, 10:39 PM   #17
larrys40
I think you sent me a pm, my box is pretty full so it might not take messages till I delete some. I have a complete trans with that setup and maybe the back and shaft. I can look if you still haven’t found one.
Let me know ….
Thanks
Larry Shepard
larrys40 is offline   Reply With Quote
Old 06-27-2022, 10:48 PM   #18
CC-Mo
CC-Mo's Avatar
Let me know ….
Thanks
Larry Shepard
Larry, yup I sent you a pm & text unless your cell # changed. Yes when you get a chance, check out what you have & let me know.
Plus, I know where you live & there’s a good Pizza place nearby.
Southern Missouri
