12-05-2013, 03:36 PM | #1 |
Can you adjust a 6v regulator?
I have a f-100 1953 with factory overdrive.The od works great until you turn the lights on,and it will not change. With the od on it shows charge but discharge with lights. can up bump up the regulator to have more out put? They both work good just not together.
12-05-2013, 03:45 PM | #2 |
Re: Can you adjust a 6v regulator?
If no other symptoms in the charging system, I'd think you might have an OD solenoid issue. For a start, check for resistance at the connections. It doesn't cost a nickel to clean and reinstall wiring terminals. Yes, the regulator is adjustable, but I wouldn't tackle that until other possible causes are ruled out.
Alan |
12-05-2013, 04:06 PM | #3 |
Thanks Alan, but i just paid $250.00 for a new od solenoid same thing.
12-05-2013, 04:19 PM | #4 |
Don't know if you have a 6 volt generator like I do but, if you do, I believe it's very much the nature of that beast. I can run one or two of my headlights, heater fan, and/or radio at one time and the generator keeps up at highway speeds; but, put all three on and it's discharging no matter what I do. I've adjusted my regulator every which way with only very slight improvement.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
12-05-2013, 06:49 PM | #5 |
The OD solenoid has two windings, a "pull in" coil that uses more current than the "hold in" coil which, as the name implies, holds the OD engaged. There are points inside the solenoid that switch from pull in to hold in depending on position of the armature. An amp meter connected to the solenoid should show a larger current draw initially, and then less after the solenoid is engaged. I don't know what the actual specs are, but they would be in the service manual. It might be worth checking the draw just to be sure it is OK. As others have said you can turn up the regulator by bending the spring tension arm.
12-05-2013, 10:02 PM | #6 |
Alan |
12-06-2013, 08:07 AM | #7 |
6 volts indicates a low battery condition. A fully charged 6 volt battery should read 6.4 to 6.7 sitting in the car before starting. Running at charging RPM's after a short time to recoup the power taken from the starter load depending on how fast the engine starts the voltage should be in the 7.2 range with a good charging system. Take your solenoid and connect it to your battery with large wires to see if it pulls in with a crisp snap. If the battery is fully charged and the solenoid is sluggish or don't snap in it's the solenoid. The number of turns of the solenoid coil wire and the spring pressure determines the voltage where the solenoid energizes. Less turns lowers the pull in voltage, higher turns put more resistance in the windings requiring higher voltage. I rewind a 12 volt solenoid for speedometer 2 speed changers to operate on 6 volts. It's about 1/2 the amount of turns with larger wire to get the 12 volt ones to operate on 6 volts. When doing this type of change you need to measure the voltage when they snap in and do heat tests to make sure the coils don't get over the heat rating of the insulation on the wire. A coil such as these and the coil of a generated mounted voltage cut out will pull in at say 6 volts but as the voltage to the energized coil is reduced will stay energized to a much lower voltage depending on it's spring pressure. The cutout pulls in at about 6.7 or 6.8 if I recall, I haven't set one up in years. The cutout coil has to be set above the normal battery voltage so the battery don't try to run the generator like a motor at idle or when the engine is not running. These new solenoids could have springs that are to strong or the incorrect number of turns or wire size since several people seem to have the same problem. G.M.
www.fordcollector.com |
12-06-2013, 06:37 PM | #8 | |
12-06-2013, 07:23 PM | #9 |
I have rewired and new wired many hot rods over the years.
I always tell the customer it will cost him twice what anyone else will charge him for material if I do it. This is because I do NOT rely on any metal part of the car for electrical returns. Anything that uses electricity on the car gets it's own individual ground wire. All grounds are then brought back to a terminal block at the battery. |
12-06-2013, 07:59 PM | #10 |
Thanks, guys I will check the grounds and add more where needed.
