Old 07-25-2020, 11:44 PM   #1
DMMuir
Default Is lead still needed?
Few odd questions from a newbie.
I know I can't get leaded gas, but I have lots of local options for Ethanol free.
Would you all recommend a lead additive?
DMMuir is offline   Reply With Quote
Old 07-25-2020, 11:55 PM   #2
deuce_roadster
deuce_roadster's Avatar
Default Re: Is lead still needed?
Lead was added to gasoline in the 1950s when high compression engines were pinging and needed the lubrication on the valves. You don't need an additive. If you ever have to rebuild the engine you can install hardened seats on the exhaust valves but an old stocker will do fine without the lead. I live near an e-free station and that is all i put in any of my old cars, chain saw, leaf blowers etc that sit around.
Old 07-26-2020, 08:56 AM   #3
Ken/Alabama
Ken/Alabama's Avatar
What year flathead ?? Most all flatheads I’ve been into from the mid to late 30’s on up to around 1950 or 51 had hard seats. I’ve seen some of the 8ba engines that were produced toward the end of the flathead era having the seats ground right into in the block , same for some of the early production flatheads in 32-33.
Ken/Alabama is offline   Reply With Quote
Old 07-26-2020, 09:47 AM   #4
rotorwrench
rotorwrench's Avatar
They started discontinuing hardened seats in 1950 or 51. Truck engines kept them on the exhaust seats only. Rotator valves coming in during the 1951 model year and modern fuels diminished the need for the hardened seats. These engines should at least have hardened seats on the exhaust valves to run unleaded fuel.
Lead additive would be unnecessary for an engine with lower compression. Most flatheads are limited on how high the compression ratio can be taken. The compression chamber has to include room for those valves to work and there is no way to get around that.
Old 07-26-2020, 11:55 AM   #5
mrtexas
mrtexas's Avatar
Started in the 30s
41 woodie https://41fordwoodie.weebly.com/
mrtexas is offline   Reply With Quote
Old 07-26-2020, 12:24 PM   #6
grumppyoldman
grumppyoldman's Avatar
If your running E-Free gas make sure you have fuel injection rubber hose, it holds up well with it. Al
grumppyoldman is offline   Reply With Quote
Old 07-26-2020, 04:05 PM   #7
DMMuir
Ken/Alabama,
it's a 1940
Old 07-26-2020, 09:22 PM   #8
Ken/Alabama
Originally Posted by DMMuir View Post
Ken/Alabama,
it's a 1940
Your good to go. They have hard seats.
Old 07-26-2020, 09:22 PM   #9
Lawrie
Lawrie's Avatar
are you sure about no seats in the early engines, all mine have them in. I have one early 33 eng with stock bore and still looks like factory babbit that came off a farm in 85 and had been in the shed there for years, it has the seats in all
Lawrie
Lawrie is offline   Reply With Quote
Old 07-29-2020, 08:33 AM   #10
Automotive Stud
Automotive Stud's Avatar
I think you have that backwards. Ethanol free gas should be just fine, but with most gas having ethanol in it now the fuel injection hose is a little more rugged and should hold up better.
Here in NJ we don't have an ethanol free option, I've been running regular pump gas in my flatheads with no additives for twenty years and haven't had any issues.
Automotive Stud is offline   Reply With Quote
Old 07-29-2020, 06:23 PM   #11
Gene1949
Gene1949's Avatar
Been running this old girl for 30 years with whatever passes for regular gas.
Enjoy the ride, no to worry
Gene1949 is online now   Reply With Quote
Old 07-29-2020, 07:40 PM   #12
grumppyoldman
Auto your right on the fuel line, I had a brain fart.
Old 07-30-2020, 05:15 AM   #13
Rudolph
Rudolph's Avatar
I add 2 stroke oil to every tank of fuel, if I have any money I use upper cylinder lubricant like Lucas or Moryes, it helps things like your carb spindles and might even help with your shitty ethanol
Rudolph is offline   Reply With Quote
Old 07-30-2020, 07:47 AM   #14
Gene1949
Gene1949's Avatar
You know guys, the subject of ethanol fuels has been beat to death on these forums. It's not that difficult to replace the offending hoses, carb parts and gaskets with "ethanol friendly" parts
The same with obsessing about the lubricating (necessity) of adding lead. There is enough lubricants in the chemical stew that passes for gasoline nowadays to make that unnecessary.
Old 07-30-2020, 09:53 PM   #15
Karl
Karl's Avatar
Rudolph I use Moreys -Would be nice if we could get MMO in NZ.
Have never used 2 Stoke oil -did read In Harold Sharon's Veteran car book that you shouldn't but can't remember the reasoning -although I do remember he said we shouldn't fight the addition of ethanol to gas - However he was talking about very early cars with very low compression and generally minimal (if any) rubber parts in contact with fuel Karl
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me.
Karl is offline   Reply With Quote
Old 07-30-2020, 09:59 PM   #16
JSeery
JSeery's Avatar
If you drive a vehicle often this shouldn't be an issue, but if they set for long periods of time it can be. I have had issues with fuel tanks and fuel lines and carburetors. I just fined it easier to use non-ethanol on all my yard type equipment and older vehicles. All the yard stuff is designed for ethanol, but that still doesn't address the issues of it setting around for long periods of time.
Old 07-30-2020, 10:45 PM   #17
Rudolph
Rudolph's Avatar
Actuality lead was a lubricant and the fuel is less oily now days, adding some oil will make things last longer
