Old 06-26-2020, 06:49 PM   #1
Tom-MI
Tom-MI's Avatar
Default Updating with a crab distributor
I need some help on this swap. I have a '35 with an original distributor. Maintenance on the distributor can be a royal pain. I am thinking about installing a crab distributor (this is not a show car). I have a '47 timing gear cover and a spacer (pictures included). If I swap out the '35 cover and use the adapter plate will I still need a spacer for the cam gear?
Thanks
Tom
Tom-MI is offline   Reply With Quote
Old 06-27-2020, 02:45 AM   #2
GaryU.
GaryU.'s Avatar
Default Re: Updating with a crab distributor
i believe the button spacer is used when a helmet style distributor is installed on a later engine like a 59ab with a three bolt timing gear cover.
GaryU. is offline   Reply With Quote
Old 06-27-2020, 03:37 AM   #3
Mart
Mart's Avatar
I believe the combo you have will work.
It would be worth checking to see if the cam has been replaced. Slim chance it might be a short nose cam with a button. If it is, you can remove the button and leave off the spacer.
If you don't want to change the front cover you can get a 3 bolt to 2 bolt adaptor that will allow the crab to bolt on.
Mart.
