Old 07-25-2020, 09:12 AM   #1
russcc
Default Filling a brakes system
Completed the '40 brake system, New wheel cylinders, master cylinder & hoses, along with flushing out and cleaning all the hard lines. What is the best way to refill the system to minimize bleeding. I am not about to invest in a "power bleeder" or whatever since I have been dong it the hard way for 60 years and it works fine for me. Thank you Fordbarners.
Old 07-25-2020, 09:25 AM   #2
Kube
Kube's Avatar
Default Re: Filling a brakes system
Russ, If you've been doing it the "hard way" for 60 years and it "works fine", there is most likely no advice anyone can give you that you've not already figured out on your own.
I've been power bleeding for perhaps 30+ years and recently (finally) had to replace my system. Cost with shipping was under $100 for one heck of a quality unit.
Kube is online now   Reply With Quote
Old 07-25-2020, 02:02 PM   #3
Joe Immler
Kube What brand, model etc is it?
Joe Immler is offline   Reply With Quote
Old 07-25-2020, 02:33 PM   #4
Kube
Kube's Avatar
Joe,
It's an ATD-5125. I'd received it April 26, 2020. It was just shy of $100 shipped.
I think (if I recall correctly) I bought it from the Tool Warehouse.
I do recall when searching the Web, this model was priced all over the place. The Warehouse was very good to work with and they shipped fast.
I am VERY happy with the quality of this unit and have little doubt it'll outlive me.
Old 07-25-2020, 02:35 PM   #5
Kube
Kube's Avatar
Joe, It went up just a few bucks. Here's the link:
https://www.nationaltoolwarehouse.co...All%20Products
Old 07-25-2020, 02:42 PM   #6
mrtexas
mrtexas's Avatar
Originally Posted by Kube View Post
Joe,
What do you use to attach bleeder to MC?
I use a vacuum bleeder myself.
Palindromes:
Do geese see God?
Was it a car or a cat I saw?
Won't Neil call a Walla Walla client now?
Dr. Gong! Get ale to my motel at Egg-nog Rd!
41 woodie https://41fordwoodie.weebly.com/
mrtexas is offline   Reply With Quote
Old 07-25-2020, 03:10 PM   #7
Kube
Kube's Avatar
I made a cap with a fitting in it. I suppose it would be easier yet to just take an extra master cylinder cap and drill and tap a hole for the air fitting.
I've always liked the power bleeding system as there is zero doubt all of the air is removed - even from the master.
Old 07-25-2020, 06:40 PM   #8
russcc
We got a little of track here. I have never had to fill a complete system, and likely never will again. It is usually one or two cylinders to bleed. So my question is, how would you start by using gravity to assist. Thank you Fordbarners.
Old 07-25-2020, 07:42 PM   #9
Kube
Kube's Avatar
The chances of gravity working well are little to nearly none.
Old 07-26-2020, 05:39 AM   #10
russcc
There must be more opinions out there other than Mike's, as much as we all value his experience. When we are referring to gravity, it is in partially filling the system so as to minimize air entrapment. Thank you Fordbarners. Any other opinions ?
Old 07-26-2020, 08:18 AM   #11
john in illinois
john in illinois's Avatar
I do not think gravity would move the fluid. I used to fill the MC have helper pump the pedal and open farthest bleeder then go to closer one ,etc. You have to always keep fluid in MC.
Now many use speed bleeders to eliminate the helper.
http://speedbleeder.com/
Now Like Kube, I use one of these pressure tanks. Made my own cap with a fitting. I hook a clear hose onto each bleeder and simply walk around opening each bleeder untill no bubbles.
The nice thing about a pressure bleeder is any leaks become immediately apparent.
https://www.amazon.com/motive-power-...+power+bleeder
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 07-26-2020, 08:29 AM   #12
joe 1950
It’s hard to gravity bleed these old systems because the master cyl. is mounted so low any car that has the master on the firewall gravity bleed pretty easy like Kube said power bleeders work the best. good luck
joe 1950 is offline   Reply With Quote
Old 07-26-2020, 08:34 AM   #13
rich b
rich b's Avatar
The power bleeder (Bendix) I used in the past had a diaphragm between the fluid and the pressurized air; I was taught this was to keep from entraining air into the fluid.
These new bleeders don't separate the two, has something changed?
Old 07-26-2020, 08:42 AM   #14
john in illinois
I always put in the fluid I think I will use and then empty and clean bleeder tank. only exposed to air for a few minutes.
I used to use the diaphragm unit in a shop and you could leave the fluid in it.
John
Welcome each day
Old 07-26-2020, 11:12 AM   #15
3twinridges
When using the power bleeder method, is it recommended to also use speed bleeders or are standard bleeder screws sufficient/recommended?
JB
3twinridges is offline   Reply With Quote
Old 07-26-2020, 11:20 AM   #16
38bill
38bill's Avatar
The "power" bleeder pressurizes the brake system and then you open the bleeder valve on the wheel cyl to bleed it. I don't think you wouldn't gain anything by using the speed bleeders.
38bill is offline   Reply With Quote
Old 07-26-2020, 11:54 AM   #17
mrtexas
mrtexas's Avatar
My Mityvac works great. No need to make special MC cover.
Palindromes:
Do geese see God?
Old 07-26-2020, 11:59 AM   #18
4t8v8
I made a vacuum pump out of an old freezer compressor. Use it with a brake bleeder cup. Works great.
4t8v8 is offline   Reply With Quote
Old 07-26-2020, 12:02 PM   #19
3twinridges
Thx bud
JB
Old 07-26-2020, 01:35 PM   #20
mrtexas
mrtexas's Avatar
I installed a remote fill MC on my 41 and mounted the two fills on the firewall above the wheels. Think this made the bleeding easier like a modern car. But also have bendix on the rear.
https://41fordwoodie.weebly.com/earlyv8discs.html
Palindromes:
Do geese see God?
