Old 07-25-2020, 05:09 PM   #1
corvette8n
corvette8n's Avatar
Default It ain't pretty but no light comes through
https://www.fordbarn.com/forum/showthread.php?t=284475
This was a learn as you go project it only the 4th time I tried mig welding and the first time with the HF welder. I had to keep dailing down the power until it stopped blowing through. I did not make a patch but started at the thickest part of the header and worked my way to the thinner parts. I had a few pin holes that I had to file and fill, but no light shows through now. It may not last but at least I learned something I hope. Is there a high tempeture paint I can put on this to pretty it up a little?
Old 07-25-2020, 05:42 PM   #2
50fordcoupeman
50fordcoupeman's Avatar
Default Re: It ain't pretty but no light comes through
I use just plain Rustoleum silver spray paint on my exhaust manifolds. It does not burn off.
50fordcoupeman is offline   Reply With Quote
Old 07-25-2020, 06:11 PM   #3
Bored&Stroked
Bored&Stroked's Avatar
You can get a high-temp header paint - from places like Jegs or Summit. I don't use paint anymore as the headers always end up rusting through it. I use ceramic coatings (baked on) - not inexpensive to pay outsiders to do, but they last.
On flathead headers, I blast my headers with about 100 grit garnet, make sure I don't handle the newly blasted headers (no oil from your hands on them), then I ceramic coat them (sprayed on with a paint gun). Once dry, then I bake the headers in a BBQ at 500 degrees for an hour. I've found that the "baked to cure" ceramic coatings are the strongest. Go out to the web and search on Cerakote High Temperature coatings - inexpensive if you do the work yourself.
Old 07-25-2020, 06:33 PM   #4
19Fordy
19Fordy's Avatar
You did good.
Old 07-25-2020, 07:40 PM   #5
Kube
Kube's Avatar
I think ya did good
Old 07-25-2020, 08:13 PM   #6
Pete
Pete's Avatar
Aluminum spray can paint or black BBQ/stove paint work for a long time.
Old 07-25-2020, 10:01 PM   #7
grumppyoldman
grumppyoldman's Avatar
Looks like a fine job, at least you got it fixed and saved some bucks. The way I shake now it probably wouldn't hold shelled corn, and I welded for a living several years ago. Al
grumppyoldman is offline   Reply With Quote
Old 07-26-2020, 12:02 AM   #8
deuce_roadster
deuce_roadster's Avatar
Hey good for you. I am impressed you did so well with little experience. I have welded stuff since the mid 1960s and I can tell you my first few jobs didn't look anywhere near that good!
Old 07-26-2020, 05:43 AM   #9
Terry,OH
Terry,OH's Avatar
Great start. keep it up !
Old 07-26-2020, 06:26 AM   #10
corvette8n
corvette8n's Avatar
Thanks for the encouragement, it's the first time I used the mig torch gel, that helped a lot.
Old 07-26-2020, 07:45 AM   #11
john in illinois
john in illinois's Avatar
When I was deciding on exhaust paint, Rustoleum barbque came up a lot on the HAMB. I used it and have driven 4 years and no rust. Corvette you did a nice job. I can not mig thin metal worth a darn. I gas welded mine.
John
File Type: jpg F211AB7C-9A6A-4935-A5C6-AA334C643CA3.jpg (75.4 KB, 33 views)
Welcome each day
john in illinois is offline   Reply With Quote
Old 07-26-2020, 08:10 AM   #12
RalphG
RalphG's Avatar
Your welds look good in the photo. When I'm welding thin metal with the wire welder I'm reminded of the old saying, "if you can't be a good welder then you need to be a good grinder". :-) It definitely applies to my work.
RalphG is offline   Reply With Quote
Old 07-26-2020, 11:17 AM   #13
19Fordy
19Fordy's Avatar
Corvette: What dia. MIG wire did you use. Just curious. Was the flux core wire easy to use?
Old 07-26-2020, 03:19 PM   #14
flatford8
flatford8's Avatar
I use grill paint. Works good....... Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 07-27-2020, 05:29 AM   #15
PeteVS
PeteVS's Avatar
I have a pipe that runs very close to my steering box and required a weld there. I haven't gotten around to it but I'm going to plus one end and fill it with water to see if there are any holes.
Old 07-27-2020, 06:47 AM   #16
corvette8n
corvette8n's Avatar
.030 Hobart wire seemed pretty easy for me, I did not use the HF wire it came with.
I pick up a container of nozzle gel, it help reduce spatter and kept the nozzle clean.
File Type: jpg 7A724E2A-1E62-4AB8-9E01-26642DB4B560.jpg (23.2 KB, 1 views)
Old 07-27-2020, 04:02 PM   #17
PeteVS
PeteVS's Avatar
I've been using .030 flux core wire. Where I was making butt welds in my exhaust system, I cut short lengths of tubing and slit it length wise so it would collapse into the ends of the two pieces I was joining. Worked out well. It's a lot trickier joining thin material without a backup, however.
I wish someone would make some .015 wire (for use with gas) for welding thin materials. I realize that wire that small wouldn't feed through a normal gun and cable from the machine but a nozzle with a spool should work.
