Old 09-28-2011, 05:56 PM   #61
Pilotdave
Pilotdave's Avatar
Default Re: UPDATE....Ok so a brand new radiator and it still runs hot
Originally Posted by TinCup View Post
Using a laser temp gauge I was curious as to temps on each cylinder looking for a hot spot. I aimed it at the bottom hose just where it connects to the water pipe. It read about 150 degrees. When I pointed it directly at the inlet neck on the side of the motor it read almost 185 degrees. I would have expected it to be closer to the 150 at the bottom of the radiator.
I suspect that it makes sense for you to get 185* at water inlet on block vs 150* at bottom of radiator, given that you were getting around 185* at outlet from block. It seems reasonable that the block would be (+/-) at one temp with the radiator cooling the water from the block temp to about 150*. I have no expert knowledge of this - just a guy trying to think about your problem. HTH
Pilotdave is offline   Reply With Quote
Old 09-28-2011, 06:55 PM   #62
Louis
My 31, after a 10 mile drive, outside temp 85-90 with the eng. at idle the temp. of the cly. head is 165-168, the temp. of the block is 155-165. I use 50/50 and if their was anti-freeze in 1928-1931 Ford would have used it.
If your car runs hot with 50/50 it will run hot on any other mix.
my opin. is you have a problem with your rad. or a block full of corr....That is, if your car runs ok otherwise.
I still think you have a rad. prob. JMHO
Louis is offline   Reply With Quote
Old 09-28-2011, 07:35 PM   #63
Jim Mason
Jim Mason's Avatar
Did you say you have a thermostat in it? Is it a 180degree thermostat? ...fwiw,jm
Jim Mason is offline   Reply With Quote
Old 09-29-2011, 09:10 AM   #64
1931 flamingo
1931 flamingo's Avatar
Are you a club member or are there other A's nearby? Any chance of swapping radiators with some one elese whose DOESN"T run hot?? How's the new water pump coming along?
Please keep us updated.
Paul in CT
Old 09-29-2011, 12:20 PM   #65
TinCup
TinCup's Avatar
Paul in CT
Just changed out water pump today. I will make a run this afternoon and see what happens. I am fortunate that I have lots of club members to help.
TinCup is offline   Reply With Quote
Old 08-27-2018, 02:20 PM   #66
30 Closed Cab PU
I know this is an old thread.
Am struggling with same issue. Do not need advice on troubleshooting. Curious if radiator and if something wrong with it, or if undersized.
Is there is an update, what resolved your issue?
Thanks
Old 08-27-2018, 03:01 PM   #67
TinCup
TinCup's Avatar
There is a much more detailed post here in the barn. Radiator ended up being an aftermarket 2 core radiator. Stock radiator was three core. Bought a replacement from Bergs Radiator and all is good now.
Old 08-27-2018, 03:13 PM   #68
30 Closed Cab PU
Thanks much, I've eliminated everything else. I have a replacement 2 row 8 fin that was installed 4 years ago by a repair shop, not sure of brand, was assured this was what they have used on other As and never had issues. My A had other issues, had to flush/backflush for 2-3 years to get all the crud out, and the head gasket was bad so it has had the top end rebuilt with coolant passages manually cleaned. This was an inherited A that had a 50 year nap. Going to do a Block test, then I guess will have to upgrade my radiator.
Thanks for the quick reply.
Old 08-27-2018, 03:15 PM   #69
TinCup
TinCup's Avatar
My old radiator was fine as long as the temps didn't get above 75 degrees. It too was a 2 row 8 fin. Had it flushed twice. It just takes 3 cores to do the job.
Old 08-27-2018, 03:21 PM   #70
30 Closed Cab PU
I see you used a Bergs 3 row. I've had recommendations of the Bergs and the Brassworks 2 row 10 fin. Why did you choose Bergs? Anything negative about the Brassworks?
Thanks
Old 08-27-2018, 03:26 PM   #71
TinCup
TinCup's Avatar
I have installed 6 Bergs radiators without a single problem. Family run business that makes a big difference to me. I have installed only one Brassworks and I had a hard time getting the radiator shell to line up. Again if you will search the barn Berg's users speak loud and clear.
Old 08-27-2018, 04:20 PM   #72
30 Closed Cab PU
Thanks much for the replies, so much info on this site, hard to sift through it and make a decision. I saw a lot of info on Brassworks QC issues, but most posts were more than 6 years old, a lot of time for that company to improve. Am a newbie at age 65, and not that familiar with computers and searching a database - thanks for your patience.
