08-03-2020, 10:53 AM | #1 |
Did I croak this coil?
I bought a new coil (helmet) for my yet to be started 39 engine. I had no power thru ignition circut so I ran a jumper wire from batt. to coil. Got engine running and ran for about 15 min. while I adj. carb. Next day installed spare resistor on coil and ran for 5 min. and coil died. Installed old coil and running again. Did I kill coil or should they be able to handle 6 volts while idling for 15 min. Got coil off eBay and it was from Carpenter and made in China. Mark
08-03-2020, 11:01 AM | #2 |
Re: Did I croak this coil?
some more junk from china. if you have the old coil send it to skip haney in fla and have it rebuilt--you will not regret it
08-03-2020, 11:13 AM | #3 |
I could see that being hard on points but I would think the coil should have held up to it. But apparently not...
08-03-2020, 02:36 PM | #4 |
The coils offered by Carpenter, made in China, were known to be problematic early on. Not sure if that problem was ever corrected, nor if they still sell these coils.
08-03-2020, 08:30 PM | #5 |
If its a carpenter coil trash it return it.. They all fail...
Carpenter makes excellent products and has been a supporter and asset to this hobby.... but their coils are the one item they sell that is a serious failure. |
08-04-2020, 07:01 AM | #6 |
08-04-2020, 08:23 AM | #7 |
Bought a 1940 coil at a swap meet for $10. then I sent it to Skip for a rebuild, this replaced the remote coil kit someone put on the car before I bought it. No regrets.
